Question about HP Color LaserJet 2600n Printer
Magenta colour is very light
In colour laser jet printer hp 1600 magenta is not working even i change 2 pcs
Anonymous
  • 55 Answers
Fist of all chack print out with useing new cartridge . if prolem not get fix than ...
that fault due to scaner problem .
u have to change scaner printer.
Posted on Apr 28, 2009
  • Anonymous Apr 29, 2009
    sorry l was write last line worng i wont to say change scaner{laser section} of printer
Anonymous
  • 94 Answers
Just try to clean the magenta laser.. i've fixed one just like this yesterday doing that!
Posted on Aug 12, 2009
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
HP 2605dn printing pale on magenta
This is likley to be the common problem (with this model of printer) of the laser unit having dirty lenes and/or mirrors.
Typically the magenta is the first colour to deteriorate.
To rectify this problem there's a fair bit of dismantling to be done in order to get the laser unit out.
Then you can open the laser unit up and clean the lenses and mirrors CAREFULLY. You don't want to scratch the surface silvered mirrors, or disturb the alignment of any of the optical components.
You'll see the same problem and solution for HP1600, HP2600, and Canon LBP5000, as they all use the same laser unit.
Feb 09, 2010 | HP LaserJet 2605dn Printer
Hp 2600n laser colour - red not working
Could be caused by a defective cartridge. Yes, even a new one can be defective. Gerrit Jan
Nov 05, 2009 | HP Office Equipment & Supplies
Hi there. Problem with my HP laserJet 1600. The
please clean up the laser unit. afther that will work just fine. have a great day.
Aug 17, 2009 | HP Hewlett Packard LaserJet 1600 Printer
I wish to clean the colour printing. I've cleaned
hello mvn 500 your printer is a inkjet say yes please remove the your colour catridge or laser printer please change the magenta ink only because laser was a 4 colour option cyan, magenta, yellow and black
Jul 02, 2009 | HP Hewlett Packard LaserJet 2605dn Printer
HP 2600N LASER PRINTER
You can try going into your print settings/preferences and checking magenta only. printers you need to keep a watchful eye on your ink levels, because if you are out of ink, you can not print in ANY color, even black.
If the above thing not works You can begin by making sure you are not using anything above 24-bit colour (RGB) in Word.
Also: Word does not use a colour profile. It doesn't make any changes to
the colour, so it doesn't compensate at all. The only colour profile
between Word and the printer is your Printer's colour profile.
Hope this helps
Sep 19, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
436 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
