back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Please check the ouput on another monitor and if the same fault is seen then the video board is faulty. This can be due to several reasons and sections and might need some expert assistance.
Low beam headlamp H11 H11SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility. H11ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility. H11XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility. High beam headlamp H7 H7SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility. H7ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility. H7EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19. H7XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility. H7CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
1. go to phone menu. 2. go to setting. 3. go to phone setting. 4. display and adjust the contrast of the screen. if this does not solve the problem, you have to change the screen of the phone.
could be your inverter board, whitch controls the backlight. I could very well be the backlight as well, but that is less likely. Inverter boards are not all too expensive, and if you are knoledgable with laptops, i would say doit yourself, but if you have any doubts, take it to apple, sur it will cost more, but it is the safet bet.
Hi, The inverter board has developed a dry or dropped joint. The inverter controls the backlight that lights up the display. Take the monitor to a reputable computer repair store and they will be able to repair the inverter for you at a small cost.
You have an LCD monitor with failing capacitors. If you have the expertise these can be purchased at Radio Shack and then you can solder them in or you can get in touch with my company at [email protected] and we'll discuss a repair plan.
