Question about Cell Phones
Get invalid number when I call voicemail
I can't set up the voicemail. When I try to call it, it says invalid number.
Posted by barbaraalves on
  • Anonymous Mar 16, 2014
    Wont register on network in australia because is saying invalid imei
taran_2005
  • 10,515 Answers
There are specific numbers for Voice mail. The number that's usually added to your cell phone might not be the updated voice mail number for your cellphone.
In order to activate this service, you need to call your service provider. They would activate the settings from their end and they will let you know how to change and set the specific voice mail number for you.
Thanks for using Fixya.
Posted on Apr 28, 2009
1 Related Answer
Oloyede Monsuru
  • 1417 Answers
SOURCE: The access code for my
The service provider will give you new access code to operate the phone and it will be install from there office i.e the voice mail.
What you need to do is to contact them from their customer care help line you will be ask some question that you can answer ,like the phone number and your location e.t.c.
Good luck please rate this four top.
Thanks.
Posted on Dec 08, 2010
I was told my password should be 9999 until I set it and it tells me its invalid password I cant set up my voicemail do to it
Try the last 4 digits of your phone number instead of 9999.
You can also dial 611 and request that the code be reset.
Aug 29, 2011 | Cell Phones
I can recieve and send messages to all of my contacts except one. when I send a message to the number it says send failed try again about 5 times, then it says message not delivered invalid...
Check weather you've mistakenly changed the contact number. If not try deleting the contact and creating it again. Remember to write the contact on a piece of paper first. Thumb me up if I helped. :)
Jul 02, 2011 | LG enV3 VX9200 Cell Phone
How do i set up my voicemail...manual not explaining ...please list steps ....
Once you call your voicemail service, you'll be taken thru step by step instructions to set up your voicemail.
To call your voicemail service
1. From the Home screen, tap Phone.
2. Touch and hold down 1.
If this does not work, you need to set up your voicemail number. Your subscription includes an answering service, callers can leave a voicemail message when you cannot answer a call. Usually, the voicemail number is saved on the SIM card. If not, contact your service provider to get your voicemail number. You can then enter the number manually.
To enter your voicemail number
  1. From the Home screen, tap .
  2. Find and tap Settings > Call settings > Voicemail settings.
  3. Enter your voicemail number.
  4. Tap OK.
Hope this helps. If so, please rate the solution.
-regards,
M
Mar 05, 2011 | Sony Ericsson XPERIA X10 Cell Phone
T7316E Voicemail Password Issues
Feature 983
password is: 1020000 (if you use 3 difit extensions)
OR
120000 (if you have 2 digit extensions)
Jul 09, 2009 | Nortel T7316E 2-Line Corded Phone
I have alltel. And everytime i try and listen to my voicemails, it asks for a security code. And everytime i type in possible codes it says invalid option. I really want to listen to my voicemails. HELP
If you just got this phone, try to use the last 4 digits of your number as a possible number. If that doesn't work, try 1234 or 0000. If none of that works for you, the only other best possible solution I could give you would be to go to the nearest Alltel store to you and ask that they reset your voicemail password for you.
Jul 08, 2009 | Toshiba DKT-2020 Corded Phone
Cannot access voicemail on Motorola Razr
If your wife never reset the codes when she used the phone, the "unlock" 4 digit PIN code is usually 1234, or sometimes the service provider resets it to the last 4 digits of your cell phone's number before sending it to you.
The SECURITY code is a 6 digit code which is set to "000000" when the phone is first sent to you and since your wife never used it that should still be it. I'd try entering 000000 for the "invalid security code" message you are getting and see if that does it. Some service providers may reset that security code before sending the phone to you too, so if any of those codes don't work you'll have to call your cell phone service provider to find out the codes. This info about all the codes was in my Razr V3 manual. Hope it helps.  If that does work for you and you can get into voicemail, then to reset the codes to your own personal ones go to ....Settings > Security > New Passwords and reset them.
If you get to the voicemail message screen and the message  stored there, (it's probably a message from the service provider) you have to call the voicemail number to retrieve the message, I just  press the keypad "dot" on the top right side under where it will say "call " and it dials & brings me to my voicemail.  The voicemail number should be stored in the phone, but because it was never set up you may have to call the provider to do so, I can't remember if it was already in there or not when I first set my phone up. Anyways......Good Luck & Happy New Year ; )
Dec 28, 2008 | Motorola Mobility RAZR V3
When I send a text message, and error comes on the screen saying "unable to send message, invalid phone or message centre number, please check the number" i have the Samsung i450
You need to call your carrier to get your assigned message center number, write this information down. Now in order to change the Message Center Number on your phone you will need to go into your Network Settings, the message center number is usually near the forwarding number (for voicemail.)
May 03, 2008 | Apple iPhone 3G
Voicemail
It is usually under message menu. try under setting of this menu. Alternatively you can use one more method that will sound funny but works. Press and hold the No. 1 key and see which number it is dialing. If the voicemail is already set it will be shown to you, edit this from the phonebook to your desired number. If the Voicemail has not already been set you will be prompted to enter you the voicemail number. Fill in the desired number there.
Feb 06, 2008 | Sony Ericsson K510i Cellular Phone
Setting Up My Voicemail
Call service provider, they can reset your voicemail options.
Nov 12, 2007 | Cell Phones
Cell Phones Logo
1,229 people viewed this question
Top Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
