Question about KitchenAid K45SS Classic Stand Mixer
Kitchenaid 5 ksm90
Which flex edge beater and glass bowl are compatible with 5KSM90 kitchenaid stand mixer
5 Related Answers
QuietRiot
  • 145 Answers
SOURCE: Kitchenaid beater rubs bottom of the bowl
Your beater to bowl clearance has come out of alignment. This can happen naturally over time and with normal use of the appliance. This is something you may correct from home using a flathead screwdriver.
Unplug the mixer, with the bowl and flat beater removed. Tilt the mixing head back as far as the machine will allow. In the exposed hinge, behind where the bowl would normally sit, you will see a 3/8 screw exposed. Turn this screw half a turn counterclockwise (to your left) in order to raise the flat beater from the bottom of the bowl.
This may take a few attempts until the beater is clearing the bottom of the bowl again. If the adjustment screw will no longer turn, do not force it. It is only designed to move so far to make the appropriate adjustment.
Be cautious. Raising the flat beater too high may leave dry ingredients at the bottom of the bowl.
If further information is needed, I would advise you to contact Kitchenaid Customer Service. They may walk through this adjustment through you over the phone and can look into ordering replacement beaters for you also.
Their toll-free telephone number is 1-800-541-6390.
Posted on Jul 08, 2009
co7196
Ned C Cook
  • 3433 Answers
SOURCE: beater is stuck on mixer
Poor some wesson oil into attachment socketin the head and work it a little by hand ----Unplug first. Work the release button and attachment.
Posted on Oct 28, 2009
Anonymous
  • 143 Answers
SOURCE: Problem for KitchenAid 300 Watts KSM90 Ultra Power
This is common problem among kitchenaid mixers. If you are hearing no motor sound what so ever, The likely cause is the carbon brushes are worn or gone completely, and will need to replaced, they are located at the left and right sides of the unit and only fit ONE way. part number for both brushes is W10260958 and comes one in a package. These are a wearable part and when gone will not create an electrical field for the motor to run. If however these are visually OK, the next probable cause of this will be the motor control board, this can cause a great deal of electrical burning smell when it goes. part number for the board is W10119326. The board can be replaced but does require some know how of the unit.Hope this helps
Thanks
Posted on Nov 06, 2009
hslincoln
Howard Lincoln
  • 235 Answers
SOURCE: Beater rubs bottom of mixing bowl.
JOE:You don’t say if you have a ‘tilt-head’or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM90P)and select the last file listed that appear under Owners Manuals:KSM90PSWW0.pdf (2930.74 KB)and save that file to your PC.You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height.I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beaterjust clears the bottom of the bowl. If for any reason, the flat beater hits thebottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks!.hslincoln
Posted on Nov 28, 2009
Testimonial: "Thanks to this answer, I was able to fix the problem in about five minutes. I am very grateful. Joe McCutchen"
hslincoln
Howard Lincoln
  • 235 Answers
SOURCE: Have a kitchenaid artesian mixer need to adjust
Hi KELLYSERMAN, this should be pretty easy to do by yourself the instructions for adjusting your beater to bowl clearance is in your Owners Manual. I you don’t have the original manual you can easily download a PDF version of your Owners Manual from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM150 and select the file listed for your model that appears under Owners Manuals (66): KSM150PSER1 (732.33KB) and save that file to your PC. Turn to Page 14 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
I hope this helps! – Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Posted on Dec 07, 2009
I need a flex edge beater for a 5 quart lift stand kitchenaid mixer model number kg25hoxaq
https://www.kitchenaid.com/webapp/wcs/stores/servlet/WHRORNAjaxCatalogSearchView?storeId=10202&catalogId=10552&langId=-1&beginIndex=0&searchTerm=Flex+edge+beater
Apr 22, 2017 | KitchenAid Food Mixers
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Dec 25, 2015 | KitchenAid K5SS Heavy Duty Commercial...
When raised to do whipping my professional 550 hd mixer attachment does not scrap the bowl to mix properly
You can adjust the mixer bowl up and down slightly. If you lower your bowl and look at the back you will see a little screw, it looks like a flat head screw and it is on the "neck" of the mixer.
You can raise and lower the bowl by adjusting this cam screw. You can tell that your bowl is adjust correctly by attaching the flat beater and put a dime in the bottom of the bowl, the beater should just barely touch the dime and move it around the bottom of the bowl.
The beater will not scrape the sides of the bowl, if you are wanting the sides of the bowl scraped I would recommend the Flex Edge Beater made by KitchenAid which is basically a flat beater with a rubberized edge which will scrape the side of the bowl as it rotates.
Here is a link to the flex edge beater on our website: http://www.mendingshed.com/kfe6l.html
Let me know if you have any other questions.
Thank you,
ColleenCustomer ServiceMendingShed.com800-339-9297
Apr 04, 2013 | KitchenAid New Professional 5.5 QT...
Bread dough beater will not come off
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
I have a KitchenAid mixer KM25GOX NSF, Model serial number WT2333793. I purchased on eBay & it is in great condition, but the flat beater hits the bottom of the bowl & the adjustment screw doesnt...
1. Unplug stand mixer.
2. Place bowl lift handle in down position.
3. Attach flat beater.
4. Adjust so flat beater just clears bottom surface of bowl
when in lifted position by turning screw
(A) Counterclockwise to lower the bowl.
5. Just a slight turn 90 degrees in either direction.
Place bowl lift handle in up position to check clearance.
6. Repeat Steps 4 and 5 if necessary.
I hope I helped you.
Jun 10, 2017 | KitchenAid 450 Watts KM25G0XWH Stand Mixer
Beater hitting bowl. Very wobbly, won't stand still when
More likely the pedestal base is bent. Your local service agent has probably seen it before and should be able to bend it back flat again. It's a brutal process with a heavy soft hammer that you probably won't want to see.
Jul 15, 2017 | KitchenAid KSM90 Ultra Power Series Stand...
Can't move the lever to start the machine - it's frozen on off position.
Unplug first. Mixers can detach from the bowl base. You may have a lockout either in the latch mechanism or in the beaters. Try removing the mixer head from the base and the beaters from their sockets. Then plug in and try switch. If not working, unplug and attach beaters. Replug and try. Then attach to base and try again.
Make sure speed control does not have safety feature requiring to press in before turning control.
Good Luck.
Jul 09, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid Classic -Mixer Head wobbles or shakes back and forth
This may have a simple solution: This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
If the beater to bowl adjustment quickly comes out of alignment, you may need to seek service. You may find a Kitchenaid certified service location locally at the following website:
http://caservice.kitchenaid.com/
Dec 14, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Hi Guys, here's my problem - How to lower the whisk on a KitchenAid KSM90? My whisk is not close enough to the bowl. Thanks so much, Helen
ok firstly if you have a stand mixer with the lift bowl you have to put a dime on the side of the bowl at the base and see how much clearence is needed to be taken away. if the dime gets moved the mixer is ok. if not take off the flat beater, take out the bowl, and look at the back of the stand. just below the motor about 2 inches you will see a screw. turn it to the left a quarter of a turn. dont over adjust do it slowly. if you have the one that you tilt the head back on do the same thing with the screw up to you get to the adjusting part. the screw will be in a different spot on those mixers. it is located in the neck of the mixer. it is right in the area that tilts back. the dime shouldnt fly around the bowl it should just gently get tapped. and never use the wisk when adjusting always use the flat attachment. and always adjust slowly never over adjust.
Apr 11, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid K45SS Classic Stand Mixer Logo
64 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Colin Stickland
Colin Stickland
Lee Hodgson
Lee Hodgson
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
