Toshiba gigabeat® X60 (60 GB) MP3 Player (MEGX60K) Logo
Anonymous Posted on Apr 28, 2009
Need Firmware for Gigabeat MEGX30
I accidentally format my Toshiba Gigabeat MEGX30 with regular format i/o using the gigabeat format. After that, everytime I turn it on it would say ''No System found on Hardisk''
I checked the manual and said I have to re-install the firmware but I could not find it on the cd product or in the folder where I installed the gigabeat software in my PC. Please help...
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 29, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
996
Points
No system found on hdd
Everytime when i switch on my gigabeat f20, it shows this error.NO SYSTEM FOUND ON HDD. i've tried formating but once this error appears, you can't do anything. Sometimes it shows SYSTEM ERROR.
Hi theofrimp109,
This error usually happens when the firmware has been corrupted or deleted. The easiest way to correct this is by updating the firmware. You may also try to restore the firmware data by following the steps below.
1. Connect the gigabeat to your computer using a USB cable.
2. Start Explorer on the PC.
3. Open the folder in which the gigabeat room is installed.
--> The folder in which the gigabeat room is installed can be opened by clicking [Start] [All Programs] [TOSHIBA gigabeat room 2.0] [gigabeat room 2.0
Program Folder]. Usually, the folder will be found in C:\Program Files\TOSHIBA\gigabeat room 2.0.
4. If you can't find the folder, please go inside the gigabeat then click on [tools], [folder option], go to [view tab] then select [show hidden files and folders].
5. Now, inside the gigabeat root, copy a folder named "GBSYSTEM" located in the folder that was opened in Step 3.
6. Use "Safely Remove Hardware" and disconnect the gigabeat.
Hope it helps.
Thank you for using FixYa.
1helpful
2answers
System error 00200060 NO SYSTEM FOUND ON HDD ona Toshiba MEGF40. I tried firmware upgrade, reformatting but not working hellp me
Okay, here's what you need to do. I'm assuming at some point yours like mine was formatted under windows. This is bad for them lol. Locate your copy of gigabeat room, and install it. This comes with a extra program in the start menu titled formatting utility for gigabeat. Format with this program, and then look under program files/toshiba/gigabeatroom/GBsystem. Copy GBsystem to the gigabeat, then turn the battery off with the switch on the bottom for thirty seconds. That should do it.
IMPORTANT NOTE!!!!!!!!!!!
This can only be done with a computer running USB 1.0. My newer computers could not "see" the gigabeat properly. I used an old machine with outdated USB to get mine to work again :) you can also check for aftermarket firmware called Rock Box, just installed that one mine, no more converting music to *.sat, it'll take straight mp3s now just like it should :) uploaded 20 gigs to it in less than half an hour :) beats the hell out of waiting ten hours for 8 gigs lol!
Installation failed: Loadlibrary error for Gigabeat f20
Hello
Welcome to Fixya's Community.
In Order to solve your Problem you need to repair the Firmware of your Device, to perform that you shoud Upgrade/Repair the firmware.
Please Download and Install the Firmware Updater and follow the instructions.
Downloads
Firmware Updater for Toshiba Gigabeat MEG-F20.
Additional Help:
Toshiba Gigabeat MEG-F20.Mnual Guide.
Thank You for Using Fixya.
Please let me know if you need any Further Info.
Good Luck.
2helpful
Could I please have more instructions on how to restore firmware data as I am still getting same results. "NO SYSTEM FOUND ON HDD" 00200060
Just install your software that came with your Gigabeat. After installation please run the following program. Start/Programs/Toshiba Gigabeat Room/Formatting Utility for Gigabeat. This will place all the files back in the hard drive. Please do not format this unit from My computer to the drive letter. You end up deleting the system and boot files. if that does not help try this in your software you right click on your gigabeat room and open it up and find gbsytem folder drag and drop into your gigabeat on your my computer screen. and then check out.try it couple of times.many times this does work for first time directly. -------- you can also try contacting topshiba service center click the link directly http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp ---------- try downloading the firmware again and installing it in your device click this link directly for firmware http://www.megaupload.com/?d=MO4S7T6I ----- This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya.
Toshiba Gigabeat doesn't work
hi there,
looks like the player is asking for a firmware update.perhaps u accidentally erased parts of it beforehand and now it is a bit on the blind side..
nevermind, get the latest firmware(gigabeat room 3.0) here:
http://www.toshiba.co.th/download/support.html
and find more info on the giga here:
http://en.wikipedia.org/wiki/Gigabeat
(choose the program fitting your windows version!)
for more support and FAQs visit
http://www.vistax64.com/vista-general/37343-toshiba-gigabeat-xp-compatible-w-vista.html>
good luck
Problem with TOSHIBA gigabeat model MEGX30
I have manual and driver for MEGX30. Let me know if you need it.
[email protected]
Gigabeat F20 and Windows Vista
hi i had the same problem and updated gigabeat room to version 3 , not the actual gigabeat just its pc software , and it seems to work ok most of the time but only if i load gigabeat watcher after plugging in my player . hope this helps ,i emailed toshiba uk but they told me that they have no intention of updating the players firmware ,
2answers
When you attempt to charge the player does they screen display the image of the charging plug? If not the battery may have died, in which case it needs to be replaced.
2answers
TOSHIBA Gigabeat 10
easy. just reload the firmware with the supplied cd. mexico
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
