SOURCE: Printing on a 3x5 card
sounds to me its software issue, the best way to do this is to go into your printer properties and check to see if it has selected 3x5 for print not 8 1/2 x 11
my wife has that problem all the time when shes trying to print pictures of the kids and ushally its due to not being setup on the printers properties you can also set it up from right here
if you go to file on the top menu here and then goto print from here we will be able to select the printer and goto the options on it and make sure the page is set for 3x5 make sure your printer is highlighted and then click on preferances and then look in there. I dont have a printer hooked upto my laptop right now so I cant give you any further steps but I know its in there.
let me know how you make out if I have to put a computer onto my laptop and give you more detail on this then I will
SOURCE: Canon Pixma MP150
i need to install driver for my canon pixma MP145 printer.
Please help, its very very very urgent
Regards
THIVAGAR
SOURCE: Canon Pixma MP830 printing red/orange hue on glossy photo paper
are you using geniune canon glossy paper??? it is designed for the printers and really is the best for the machines
SOURCE: I need to download the software/Canon Pixma MP 240 series printer
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=2610&modelid=17161#DownloadDetailAct
go to this site and put in your operating system and you will get the drivers you require. I would uninstall the all of the older drivers reboot then install the new drivers. Remember not to connect your print to your computer until the new installing driver tell you to.
Hope this does the trick for you, good luck. Please leave a rating, thank you kindly
SOURCE: Pixma Pro 9000 Canon Printer is printing terribly
You need to check your nozzle check print and see if all the colors print. Also many generic inks are not the right color. Take out your yellow cartridge and see if it's still yellow, if it's orange or brown you need a new printhead, there's a membrane inside that keeps the colors separate and when it breaks you get cross contamination of the colors.
