Question about Electric Mobility Health & Beauty
A key broke off in the ignition of our handicap motorized scooter
Posted by Crystal Hammack on
Specs Healthcare \ Avia Mobility
    Scholar:
  • 90 Answers
This is a common issue with the travel scooters. It is usually an easy fix without having to replace the key-switch.
You need the following tools:
Good eyesight and / or good glasses to see down inside the key switch. A strong, thin needle. A jewelers flat screwdriver or eyeglass screwdriver.
The broken key inside the switch will have a flat back and a toothed topped. The toothed side moves a series of spring loaded pins inside the lock.
With the switch turned to the off position...
Place the jewelers screwdriver down inside the switch where the key's teeth are, pushing back the spring pins, and getting leverage under one of the teeth to lift the key out.
The needle is used to release friction and back pressure off the key back against the switch housing.
Work it carefully and be patient.
Once the key piece is out try ebay for a replacement if needed.
A common key number for Pride scooters is the A126
Posted on Oct 28, 2013
I broke my key off in my ignition on my Tao Tao 50cc scooter how can I start it until I get a new key switch ignition
Hi, Anonymous I would take the switch to a locksmith he can remove the key for a beer for more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Hotwire the ignition switch
TaoTao Scorter Starting switch work around
How to hotwire Chinese Scooter
TaoTao 50cc Scooter Owners Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 21, 2016 | Motorcycles
Key broke in barrel
Hi Debbie, pelase contact me and i can supply you a new low cost barrel with institutions on how to fit it.
Regards
Rob
www.gewizrepairs.co.uk
Mar 06, 2014 | Pride Go Go Elite Traveller Plus 4 Wheel...
Remove broken key from ignition
you might try putting a 'footie' stocking over the end of a vacuum cleaner hose (to catch the part when it comes out) and then pressing the covered end against the keylock hole and the part might just get sucked out
Oct 28, 2013 | Health & Beauty
Amigo handicap scooter -- loosing distance with in use
you'll need new batteries plan on replacing them at 1-1/2 to 2 years
Oct 14, 2012 | Amigo Health & Beauty
The electric brake that is on the end of the 24 volt motor doesn't release
krazy the brake will have to be replaced contact the provider where you got the scooter to ask if they can repair it. If not you can contact Repair Xpress @ 1-877-581-3733 to see if they have a tech in your area Hope this helps
Apr 20, 2011 | Electric Mobility Handicap Scooter
On a odyssey handicapped scooter 4 wheel new do you have to connect the battery or is it connected at the factory
Harv if you turn the scooter on and the lights come on then the batteries are connected. Yes charge before use and the provider that sold you the scooter should have installed the batteries
Mar 11, 2011 | Health & Beauty
Ignition switch damaged by vandals on motor scooter. How do I replace. The product category is Peugeot motor scooter ( not as described below) I had to get through somehow.
identical to a previous inquiry, remove any headstock covers and locate a recessed grub screw, insert Allen key, remove and extract ignition barrel usually by pushing down.if it dont move dont force it you may have to turn key!
Sep 07, 2009 | 2005 Factory bike Chrono SM 250
Health & Beauty Logo
299 people viewed this question
Top Electric Mobility Health & Beauty Experts
Rob Hill
Rob Hill
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
