Question about Samsung Star Cell Phones
Phone is starting again and again main menu does nt come
Posted by Vikash Paswan on
Rinoo Kumari
  • Samsung Expert
  • 2,973 Answers
Re-install the firmware using Samsung Kies on your pc or laptop.
Posted on Oct 28, 2013
MY samsung GT S3850 is restarting again and again once i switched the phone on
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Oct 24, 2012 | Cell Phones
Micromax A57 mobile main menu option displayed, so how to get the back the option
Hey , Even im also facing the same problem.. can you help me out how to get back my home menu icon ..
Oct 22, 2012 | Cell Phones
Windows 7 nt wrking in laptop
Here are the steps to Activate windows by Phone
1. Click on start, type: “slui.exe 4” in start-search box and press enter.
2. Select the Nearest location from the drop menu.
3. Click on Next.
4. From the next window dial the toll-Free number displayed.
5. Enter the installation ID and get the Confirmation ID
6. Enter the confirmation ID the phone system gives you.
7. Click on Next to complete the activation process.
If you are unable to activate Windows by performing above steps, then you can contact the Activation Department at 1800-936-5700.
Mar 08, 2010 | Acer Aspire 4730-4516 Notebook
How do i fix my cell phones screen...its white
first adjust the contrast by going to display settings in the main menu.if nt corrected even,there is a problem with the lcd,get it replaced.
Dec 04, 2009 | Motorola Mobility RAZR V3
Good day, pls. help me, how can i install network ip address for konica 7035. thanks alot
Using arp command (Windows 95/98/NT/2000)
From Windows 95/98 MS-DOS prompt or at Windows NT/2000 command prompt, you can use the arp
command to assign the IP address to the network interface card. It is necessary that TCP/IP is set up
correctly on the computer that will execute the arp command. Perform the following procedure:
1. At Windows 95/98, select [MS-DOS prompt] from the [Start] menu. At Windows NT/2000, select
[Command prompt] from the [Start] menu.
2. Execute the arp command. For example, if the MAC address of the network interface card is
00:11:22:33:44:55 and the IP address to assign is 192.168.0.128, then input as shown below,
and then press [Enter].
(Example: C:\>arp -s 192.168.0.128 00-11-22-33-44-55
3. Execute the ping command for the assigned IP address. In this case no response is returned
from the network interface card.
(Example: C:\>ping 192.168.0.128
4. Turn off the main power supply to the print controller and the main body printer, then turn it
back on.
Chapter 2 Setting Up the Network Interface Card
2-4 Konica Network Interface Card INSTRUCTION MANUAL
A Status Page will be output. Check that the IP address is correctly set in the list. Or, when about 5
minutes have passed after having restarted the print controller and the main body printer using the
ping command, check that the network interface card responds correctly. The ping command is also
executed at Windows 95/98 MS-DOS prompt or Windows NT/2000 Command prompt. The example
of executing the ping command is shown below:
Aug 31, 2009 | Office Equipment & Supplies
MOTOROLA V3i
first cheak vibration setting in setting menu if its off turn it on. if still nt working get ur ******** fix it will take 150-200 bugs
Jul 27, 2009 | Motorola Mobility RAZR V3
Cannot get the menu page and cannot turn off
Remove the battery for few minutes and then start your iphone again
Jun 17, 2009 | Apple iPhone Smartphone
Reinstall Firmware
you will need to take the phone to a mobile service center and have them reflash the phone for you.
Jun 12, 2008 | Nokia 5200 Cellular Phone
Cell Phones Logo
21 people viewed this question
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
