Question about Canon EOS 5D Mark II Digital Camera
5d mark II working without memory card ,but with memory card no working, how to resolve this problem
    New Friend:
  • 19 Answers
I have seen this problem some times. Usually it comes from a fail at the CF PCB (compact flash printed circuit bard) and it is necessary to change the board. Sometimes the problem is the "bent pin syndrome" that frecuently occurs by using cheap Flash Cards.
Posted on Oct 29, 2013
5 Suggested Answers
Anonymous
  • 17 Answers
SOURCE: I have Canon 5d Fullframe Camera,Its Showing
Error 99 is a lens issue. Try this.
Posted on Mar 16, 2009
Ty Price
  • 11967 Answers
SOURCE: how do you remove LCD cover on canon 5D mark II.
Google the words...disassemble a digital camera.
Posted on Oct 16, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Canon EOS 5D Mark II whrer is the selftimer botton
Self timer function is mentioned on page-86 of manual.
Below image is part of user manual that will help you to turn on self timer.
Thanks.
Posted on Jun 16, 2010
wesjoyce
  • 8 Answers
SOURCE: my canon 5d mark II
I've encountered this problem with a 5D Mark II and the problem was the card. Our card was a 16GB Sandisk Extreme that was just as new as the camera. Make sure your camera's firmware is up to date. If your card is high in GB your camera will have a hard time poring with it if the firmware is old. But as we figured out, our card was bad, plain and simple.
Posted on Mar 05, 2011
tinualbinale
TINU ALBIN ALEX
  • 436 Answers
SOURCE: The language on my Canon
Follow the correct instructions below based on the diagram to change the language of Canon EOS 5D Mark II from Japanese to English;
1.Press the MENU button.Different tabs are displayed on top of the screen as shown below.
2.Turn the Main Dial to select the tinualbinale_33.png Setup Tab ( The one with two dots and a spanner) on top of the screen.
3.Under this tab Turn the Quick Control Dial to select [Language] ( the third item from the top ) and press the SET button.
4.To select the desired language use Main Dial or Quick Control Dial (The current setting is indicated in Blue) and Press the SET button.
5.The desired language is set.
Thanks for choosing Fixya
Posted on Jun 20, 2011
How to fix canon 5D mark 2 error #30?
On the 5D error code 30 appears to be shutter related and general advice is to get a professional repair or send it back to Canon.
Aug 04, 2014 | Canon EOS 5D Mark II Digital Camera with...
Tip
1080p MOV Conversion-Import/Edit Canon 5D Mark II MOV to FCP X with ProRes...
1080p MOV Converter-Transcode/Edit Canon EOS 5D Mark II 1080p MOV to ProRes 422 for FCP X <br /><br />Canon EOS 5D Mark II is one of the best DLSR made by Canon. It shoots full HD 1920x1080p videos in MOV format. However, with the high quality MOV videos, you may find that the log and transfer method on FCP X does not work for them .Therefore, In order to edit the videos of Canon EOS 5D Mark II, <b><a href="http://www.aunsoft.com/video-converter-mac/">1080p MOV Conversion for FCP X</a></b> is necessary. I googled and found Aunsoft Video Converter for Mac as the perfect. <br /><br />How to <b><a href="http://1080p-converter.com/2011/07/top-notch-mac-camcorder-conversion-tool-convert-canon-5d-mark-ii-mov-to-prores-for-fcp-x-editing/">Import and Edit Canon EOS 5D Mark II MOV to FCP X</a></b>? <br /><br />1. Transfer Canon EOS 5D Mark II MOV to Mac <br />Connect Canon EOS 5D Mark II DLSR to Mac with a USB cable. Copy the MOV files to hard drive on Mac or from outside. The MOV videos will be soon transferred to Mac computer. <br /><br />2. Load 5D Mark II videos to Aunsoft Video Converter for Mac <br />Run Aunsoft Video Converter for Mac as the <b><a href="http://www.aunsoft.com/video-converter-mac/">Top-notch Mac Camcorder conversion tool</a></b>. Click the "Add" button to load the MOV videos to the program. <br /><br />3. Choose output format and destination <br />Click the "format" option, and choose Final Cut Pro &gt; Apple ProRes 422(HQ) (*mov) as the output format. Click the "Browse" button to specify the output destination. <br /> <br />4. Convert 5D Mark II MOV videos to ProRes 422 for FCP X <br />After the output format and destination are set, click the convert button under the preview window, wait just a few minutes and the converted Video from <b><a href="http://www.aunsoft.com/video-converter-mac/">Canon EOS 5D Mark II MOV Videos to ProRes 422</a></b> will be ready for you to edit on FCP X. <br /><br /><b>Tips:</b> <br />Aunsoft Video Converter for Mac can also convert videos for other softwares like <b>iMovie, Adobe Premiere Pro, Final Cut Express (FCE)</b> and various media devices like <b>iPhone 4</b>, <b>iPad </b>and <b>Motorola XOOM</b>.
on Jul 27, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Canon 5D Mark II error 80
Error Code 80 on the 5D II indicates the a
Malfunction related to the electric control of images has been detected.
Apr 18, 2014 | Canon EOS 5D Mark II Digital Camera
Memory card release button broken
The card release assembly is located on the back of the rear main circuit board. This is not a repair I would recommend to someone who is not used to dealing with static sensitive circuits and does not have an anti-static setup for repair
Oct 26, 2013 | Canon EOS 5D Mark II Digital Camera
Cannon EOS 5d mark 3....it is in another language...how do you change it to English. I see the answer for mark 2 but this doesnt work on mark 3?
I was able to download the manual from Canon USA for free. I could search the page for you, but perhaps you also want the manual and read it yourself? here is the link to the download page:
EOS 5D Mark III
Oct 21, 2013 | Canon EOS 5D Mark II Digital Camera
Memory card folder changed from EOS to EKS
Have you tried formatting the card in camera? Always format cards in camera, don't just delete all photos.
If that doesn't work, format the card on the computer in FAT32 and then format in the camera.
Apr 08, 2013 | Canon EOS 5D Mark II Digital Camera
My canon 5d mark II won't format memory cards. It keeps asking me to format, and then telling me it cant format that card and to switch it out. I've tried 3 different cards, none of which have ever been ...
Feb 05, 2011 | Canon EOS 5D Mark II Digital Camera
My 5d mark 11 camera screen appears error20 and it wont remove
Hi
Error code 20 on a Canon EOS 5D Mark II indicates there is a hardware problem with either the mirror or the shutter. The only solution is to have it repaired - or if the camera is reasonably new take it back to your supplier and get your money back.
Hope this helps
David
Jan 13, 2011 | Canon EOS 5D Mark II Digital Camera
Canon EOS 5D Mark II Digital Camera Logo
73 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
