Samsung SGH-i900 Omnia Unlocked Cellular Phone Logo
k
kimo Posted on Oct 28, 2013
Usb driver install - Samsung SGH-i900 Omnia Unlocked Cellular Phone
saqib ali
Level 1:
New Friend:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Oct 28, 2013
saqib ali
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
17
Questions
0
Helped
173
Points
51
Brother agr usb driver instal ni ho raha to jack ka proble ho sakta hai and 2nd agr win 7 hai to google sy download kar k chk kar lo driver
1helpful
Usb not recognized
1st You download Webcam Driver.
Usb not recognized
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
3helpful
2answers
USB 2.0 PORT NOT WORKING
try these ways:
1-reinstall your motherboard's driver.
or 2-download and install a new driver (go to Intel official site and search "Intel G965 Chipset")
or 3- connect an external USB hub to *********** board and use external USB ports.
2helpful
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
1helpful
2answers
I NEED A USB DRIVER
USB drivers will be automatically installed by your operatinf system. The thing is you need to install the driver for any device which you are going to connect via USB.
For example, if you are going to connect your printer to USB port, then you have to install the driver for your printer only and not for the USB port.
I hope this is helpful for you to understand about your problem.
Thanks
4helpful
Motorola phone tools does not find my motorola v235
Did you download and install the Motorola USB Data / Modem drivers? If not, you will need to.
Motorola Mobile Phone USB Drivers (for Windows®) This USB Driver is used for connecting your Motorola Mobile Phone to a Windows® computer via a USB cable in order to charge your phone or to access the data on your phone.
Supported Handsets This USB Driver supports most Motorola OS, Motorola Linux OS, Motorola iDEN, Motorola Symbian/UIQ, Motorola Windows Mobile® and Motorola i-mode Handsets.
System Requirements
  • A 32-bit or 64-bit version of Windows 2000®, Windows XP®, Windows Vista® or Windows 7® Operating system.
  • You must have Administrator permission to install this driver.
Notes
  • Please reboot the system after installing the USB Driver.
  • Installation of Motorola Phone Tools may affect the performance of this driver. Please re-install the USB Driver after the installation of Motorola Phone Tools.
* MotoConnect is a PC application that keeps your Motorola device drivers up-to-date. Additionally, on supported phones, MotoConnect can launch the owner support page for your phone giving you easy access to user guides, FAQs, tutorials, videos and more.
Go to this website and sign up to be a member. You can then download the USB drivers there.
How to connect motorola w388 model to pc to access internet
System Requirements
  • A 32-bit or 64-bit version of Windows 2000®, Windows XP®, or Windows Vista® Operating system.
Notes
PC Charging Drivers These drivers allow you to charge your phone using your PC and a USB cable.
Feb 05, 2010 • Cell Phones
Usb audio driver won't install from original cd
Installing USB sound card (any windows)
  1. Do not connect or plug the USB sound card
  2. install the software and driver
  3. restart the computer
  4. connect the USB Sound Card
  5. windows found new hardware
  6. select find hardware automatically.
  7. if windows cant find the driver select browse CD (contain driver)
i have 3 soundcard installed in my computer (XP Pro SP2,Vista Enterprise,Ubuntu Linux) 1 built in and 2 USB.
built in I use for speaker, 1 USB I used for monitor to my DJ mixing software, 1 USB I used for telephone(VOIP)
I have driver cd but USB driver dose not support to window vista
dear windows vista not support this driver .please install widows XP and install usb driver.
3answers
Touch pad and usb ports
did u install mother board drivers /not ? install M.bord drivers.
chk all usb ports are connected to mother board.
if problem persists go to decice manager expand USB then right click on usb driver select uninstall.
right click on usb select scan for hard ware changes .system will install that drivers automatically.
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
