SOURCE: JVC LT-23X475 flat screen TV
capacitors are most likely to blame here, there are several that most likely are on the power board and are blown if you get them replaced the tv will function normally, the heat can come from the transformer since it is not getting smooth power from the capacitors. it is working very hard to dump the spikes in the electricity. I ups backup power supply rated for the tv's wattage will help smooth power and protect your investment.
SOURCE: JVC LT-W26X84 setup problem
You need the remote for this= an exact one!
GOOGLE THE MODEL NUMBER WITH "REMOTE" AND DO NOT BOTHER WITH A universal---waste of money as it will not have key functions you need.
SOURCE: JVC Mod. CT-24EM74
Sounds like back-light inverter fault. Shorted component/s at it. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
