The 7730 is a smartphone (PT) that connects to a Panasonic Hybrid exchange such as the KTES824 as an EXTENSION not a CO.
When you say greeting do you mean a recorded greeting when calling the extension?
In the 824 switch you will need to activate the Automatic Attendant (AA) that is built-in
Testimonial: "thanks a lot but im afraid, still i did'nt get it.what im trying to ask is that, the greeting that the caller will heard once you ring the phone."
SOURCE: advanced hybrid system panasonic kx-t7730
how do i change my voice message on my answering machine??
SOURCE: how do i set the date on my panasonic kx-t7730
With the handset on the cradle press Program * # followed by the system
password ( default is 1234). Now press 000 and then Sp-Phone.Enter the
year and then scroll to the month with the right scroll key (located at
the right bottom corner of the phone). To change the month use the AUTO
ANS / MUTE button. Now scroll right again and change the date and day.
To change the day again use the AUTO ANS / MUTE button. Now scroll
right again and the time will appear. Set the time. To change am/pm
scroll to it and again use the AUTO ANS / MUTE button. Press program to
exit program mode and your done.
Please rate this answer if it was helpfull
Thank you
SOURCE: panasonic kx-t7730
Hello, if you are using this phone with a 308 or 824 system, while the handset is still on the cradle / hook press PROGRAM and then the one touch button you want to assign a CO line to. Now press 0 followed by the line port number ( example 1 ). Press AUTO DIAL / STORE to save the changes. Press PROGRAM to exit program mode.
PLEASE vote if this was helpful
SOURCE: how to set the clock at a panasonic kx-t7730
Basically, there are 2 ways of programming the date
and time - the short way and the long way.
If you are using the KX-T7730 phone on a Panasonic
KX-Txx 308/824 system:
SHORT WAY:
From the Switcboard / Main telephone
( ext 101, 10 or 9 ) with the handset on the
cradle/hook:
1. Press PROGRAM 0
2. Enter Date and Time
( The format is: yymmdd,
1 to 7 1=Monday 2=Tuesday etc, hh:mm,
0 or 1 0=AM 1=PM ) see example
3. Press AUTO DIAL / STORE to save your changes
4. Press PROGRAM to exit program mode
EXAMPLE:
If the date and time is 3 February 2010 Tuesday 2:15 pm you will enter as follows:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook:
1. Press PROGRAM * # followed by the system
2. Now press 000 and then SP-PHONE.
Enter the year.
3. Scroll to the month with the right scroll key
(located at the right bottom corner of the phone).
To change the month use the AUTO ANS / MUTE
button.
4. Now scroll right again and change the date and
day.
To change the day, again use AUTO ANS / MUTE
5. Scroll right again and the time will appear.
Set the time.
To change am/pm scroll to it, and again,
6. Press PROGRAM to exit program mode and you
are done.
SOURCE: How do I change the time on a KX-T7730 phone?
SHORT WAY:
cradle/hook:
1. Press PROGRAM 0
EXAMPLE:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook:
Enter the year.
button.
day.
Set the time.
are done.
