What exactly is this 'loud noise'? Is it a constant grinding or rumble sound that changes with drum speed or is is an occasional thumping, banging noise as the drum speeds up or slows down? A grinding or rumble is often a drum bearing and Thumping is commonly the 'suspension' the drum rides in to stop it 'walking across the room or shaking itself to pieces as it goes into high spin speeds. Your machine's age will only affect you if it is a very old machine and parts are difficult to find.
Hi, The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
