Question about Just Wireless Bluetooth Headset Wireless Headset
Code for btmp-50k - Just Wireless Bluetooth Headset Wireless Headset
E 66 error code
Fran,
This is a Heating element relay failure code, Check the resistance of the NTC. Is it around 50K ohms?
if No. Replace the water inlet valve assembly.
Mar 27, 2012 | Washing Machines
Eror problem bitmap dll
bitmap is a program to view and or edit your photos with the paint program. Try to go in to your file and click on file at the top, then go to save as and change the file type to something other than .btmp. Once you have saved the file as something else try to print again and you should be good to go.
Nov 09, 2010 | HP Office Equipment & Supplies
My 07 pt cruzer engine light is on so i did the off on off on and the code that came up was p 0340. what does that code mean?
Try the dealer, call the service department for a correct answer. It probably is just the pre-programmed normal engine check for the catylic converter. These lights usally go on about 50K miles, then it makes you panic and send it to the dealer. He then flips a little switch under the dash to make it go out until the next 50K miles goes by, then he checks the converter for clogging or such and then charges you. Without knowing the code meaning, this is what I would suspect it to be.
May 12, 2010 | 2007 Chrysler PT Cruiser Touring Hatchback
What is perfomed on the 50k servie
If you have the owners manual, that should tell you eveything that needs to be done at 50K.
Jan 09, 2010 | 2004 BMW Z4
2007 Honda Fit with 50K. Intermittently misfire.
Buy some Seafoam from autozone $10 pour half can into half tank drive a little hard on it for a good 10 t0 15 miles. this should do the trick. let me know if it helped!
thanks.
Sep 26, 2009 | 2006 Honda Fit
Need to change my BTMP's into JPG's
Thanks for allowing me to help you with your problem. If you mean you want to convert .bmp files into .jpg files, you can do this very easily. Here's how:
  1. Click start
  2. then accessories
  3. then Paint (Windows only)
  4. From the program, click file, then open.
  5. Select the file you want to convert from whatever location you have placed it.
  6. Open the file in Paint.
  7. Then click file, then save as.
  8. In the window that opens, type a new file name, then save.
If my assistance helped you, please take the time to give me a rating.
Thanks for using FixYa.com
Jan 28, 2009 | Computers & Internet
Unlock Nokia E61
hi! you get here:
www.nokia.com.au/A4520054 - 20k -
www.unlockme.co.uk/unlockme.html - 50k -
nfader.z-host.ru/ - 7k -
Jul 17, 2008 | Nokia 5200 Cellular Phone
Code
try here:
unlock.nokiafree.org/ - 46k -
Jul 16, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
I forgot my lock code.
you got from here:
www.indiamobiles.com/nokia_cheat_codes_india.htm - 45k -
www.unlocks.co.uk/ - 35k -
Jul 16, 2008 | RIM BlackBerry Curve 8310 Smartphone
Just Wireless Bluetooth Headset Wireless Headset Logo
Top Just Wireless Radio Communications Experts
Rocketmanusa
Level 1 Expert
Anthony Ward
Anthony Ward
robert
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
