Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor Logo
A
Anonymous Posted on Oct 27, 2013
I need a replacement part part for my Clarke bronco aircompressor model #AC2000B. I have no manuel on this product. Can you help me?
Need matco 160 repair manuel
Hi:
Here's Clarke's owners manuals web site, just choose your model and download it.
http://www.clarkeservice.co.uk/product_manuals/mig_welders.shtml
Don't forget to rate me.
Ac2000b motor runs but builds no pressure in tank
Your compressor is worn out. It is repairable but you will quickly find out that the price of the rebuild kit and S+H is about the price of a new compressor at your local store.
Oil-less compressors cannot stand up to use and abuse they get like a oil compressor can but they are certainly affordable.
Thanks for your question @ FixYa.com
Clarke AC2000B Compressor. Just keeps cycling on & Off like it's overheating
This can be a symptom of a waterlogged receiver tank. Obviously drain the tank if it is. Another possible problem is a stuck start switch. If it is overheating you will find the motor very hot to the touch. If this is not the problem you will have to put a ammeter on the motor to see if it is drawing the stated run current. If motor current is normal then it may be a bad thermal sensor in the motor. This compressor is a very low cost unit, and it may not pay to take it to a repair shop.
1helpful
Need manual for 100E MK2
Hi:
Follow this link for clarke models pro-90, 100E and 150TE MIG,
http://www.mig-welding.co.uk/forum/files/clarke.pdf
If this help was useful, please vote.
Thank you
I need a manual for a clarke bronco 6 gal compressor (ac20008). When I use the unit, I am cutting the circuit breaker off.
I would try a different outlet ( which should be on a different breaker ) -- sounds like your breaker is either bad or to low of a amp rating to handle the load of the compressor.
c...
Top Clarke Air Tools & Compressors Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
