SOURCE: Error: installation ended prematurely because of an error
That is the problem with VISTA...Those softwares which were workin in XP is not supported by vista...(different platform)...or else go for the software developer and get the vista version
PLEASE VOTE ME AS FIXYA (blue boxes) for my help.........
SOURCE: installation ended prematurely because of an error >> office 2003
Firstly is this a copy or original and were you online during install. A copy i cant help with.
However, cd's have the problem of grease or dirty surfaces. and although the underside needs to be clean its the top that you should protect from damage as this is where the data is held. Try taking the cd to the sink and washing it with a drop of washing up liquid and drops of water. wash entire disk and swill with wram not hot tap water. when desoapped, drip dry and dabb onto a clean kitchen cloth. never rub towel onto disk surface. hold disk by finger in centre hole and on disk edges only. ensure entire disk is dry before insertion. Check cd rom drive head is free of hairs fluff etc.
AndystUK
Hello and Welcome to FixYa.com
Removal Procedure 1. Disconnect the negative batten' cable 2. Remove the audio system trim plate. 3. Remove the screws and the audio system. 4. Disconnect the audio system electrical connectors. Installation Procedure 1. Connect the audio system electrical connectors. NOII: Dis similar metals in direct contact with each other
may corrosion de rapidly. Make sure to use the correct fasteners to prevent premature
corrosion. 2. Install the audio system with the screws. Tighten Tighten the audio system screws to 4 Nm (35 lb.in). 3. Install the audio system trim plate. 4. Connect the negative batten' cable.
Thank you for using FixYa.com
Regards, Lee Davidian
Your FixYa Expert
