Question about Kenmore HE2 Plus Front Load Washer
Does anyone know the code to make a HE2 Plus "spin only"?
Before I purchased my HE2 Plus 18 mo. ago the sales associate punched in a code to make the machine "spin only" on the sales floor. This was done to demonstrate the rpm's available. This would come in useful when I have a load the won't spin out.
Posted by chankgj1 on
Rex Hays
    New Friend:
Select the rinse/spin cycle turn off the second rinse and voila, you have spin only!
Posted on Aug 22, 2015
Michael Childers
  • 240 Answers
Select the Spin/Drain cycle. any special code would have been the service/diagnostic mode but that wants to run a factory test which involves water fill and agitate
Posted on Apr 28, 2009
My Kenmore HE2 plus front load washer is showing an error code and now it wont spin or unlock what is wrong with it
Your pump is blocked.prob a hair bobble coin etc... try the pump access at bottom of machine water will come out so u need to open it slowly
Jun 03, 2016 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
I have a kenmore HE2 plus with error code F33 and F21. Washer is not fully spinning out and remains full of water at times and other times it does. What are the error codes and can it be fixed. Needs...
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
CLICK HERE
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa&^%%$
Jan 08, 2011 | Kenmore HE2 Plus Front Load Washer
What does F5 mean??????
To to: http://www.managemylife.com/mmh/owner_manuals/search?query=Kenmore+HE2+Plus
First you must find your washer's model# & serial# but here is a location which contains repair manuals and views of your machine with a "code exchange" to help you determine what "F5" means. Consider purchasing a repair manual if you plan to keep the machine.
Oct 08, 2010 | Kenmore HE2 Plus Front Load Washer
My Kenmore He2 at the end of wash my clothes are still heavy with water and a f01 code is flashing
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 08, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore Front Loading h2 (110.46462501). Was not spinning out water or going into high speed spin. Replaced belt (was stretched) and will spin out light load but not heavy. Tried heavier load and during...
I need to know specifically which lights are on...And if this is an HE2, He2 plus, or HE2T,,,
The lights give the error code to be certain... Also tech sheet behind front bottom panel will help identify error code and how to diagnose exact problem.
Mar 20, 2010 | Kenmore 46462 Front Load Washer
Very loud spinning cycle
was the shipping bolts removed when it was delivered there are four in the back
Mar 29, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
1,506 people viewed this question
Michael Thomas
Michael Thomas
Harvey Mahal
Steve F
