Question about Kodak EasyShare Z760 Digital Camera
How do you find the white balance on this camera?
Posted by nia mccullum on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
It's in the Setting menu under "White Balance." See pages 27-28 of this manual: http://www.fixya.com/support/p261922-kodak_easyshare_z760_digital_camera/manual-3749
Posted on Oct 28, 2013
Sean Kelly
  • 37 Answers
This camera does not have a customizable white balance. It does have some presets -- they are:
  • Auto (default)-automatically corrects white
balance. Ideal for general picture taking.
  • Daylight-for pictures in natural lighting.
  • Tungsten-corrects the orange cast of household
light bulbs. Ideal for indoor pictures under tungsten or
halogen lighting without flash.
  • Fluorescent-corrects the green cast of fluorescent
lighting. Ideal for indoor pictures under fluorescent
To access them, press the [Menu] button and look for White Balance -- the icon is a Sun and Light Bulb symbol.
What is white balance
White balance is the camera looking at the whitest white and the blackest black and aligns all the other colors between the two digitally. when you adjust the white balance you create end points for how light the lightest or darkest point in your photo can be collected on your camera.
May 01, 2014 | Panasonic Lumix DMC-FX12 Digital Camera
I could not found white balance in shooting mood
You can set the white balance only in one of the P, S, A, and M modes. In the point&shoot modes the camera will always automatically set the white balance (and just about everything else).
In one of the PSAM modes you can set the white balance in the Shooting menu. Full details are in the "White Balance (P, S, A, and M Modes)" section of the manual (page 70 in my copy).
Mar 22, 2012 | Nikon D40 Digital Camera with G-II 18-55mm...
Is it possible to turn off the white balance in a Sony Cybershot DSC H5?
White Balance is not a setting that can ever be turned off, it is simply your camera's way of telling what is white so that it can process colors correctly. You can however adjust the white balance manually or simply set it to auto. Auto white balance usually works great and I would highly recommend using it. To adjust your white balance, here are the steps:
1) Press the menu button. scroll using your arrow pad to the WB option and then press the Control Button.
2) This should bring up your white balance selection screen. Keep in mind that if your camera is in full auto ( the dial is set to the camera icon ) you will not be able to adjust your white balance.
I hope this helps!
May 05, 2011 | Sony Cyber-shot DSC-H5 Digital Camera
White balance on D50 set correctly?
Are you saying that you're using a white background but it doesn't appear white in the pictures? If so, then yes, you need to change the white balance to match the light. Probably "tungsten" but you could try different settings and pick the one you like best or you could use a white piece of paper and set a manual white balance.
Oct 24, 2009 | Nikon D50 Digital Camera
Unsteady White balance
You must switch to preset, push the awb button on the front to switch from auto white balance indoor to auto white balance sunlight (3200k to 5600k). This will automatically balance the camera to the approximate settings needed. For fine tuning the white balance.....
If you want to set the A and B buttons, first switch to A, then hit the Auto button by the user 1,2 3 button until you are off of auto total white auto focus auto iris mode AWB A ch will show in the viewer hit the Auto again and ATW shows, meaning Auto total white is on, and you will not have control over the white balance, it will continue to float and try to automatically balance in the middle of your footage. Once you are on AWB A ch from hitting the AUTO button, then point the camera at the white you are balancing to (of course put the white under the lighting you want to balance to) push the AWB button on the front of the camera and hold it in until the camera goes through the white balance mode and the black balance mode,...the camera will go dark while this is being done but an OK with the correct color temperature will show briefly on the screen when it is done and you can release the AWB button. Now you have set the A button to the white balance for the current lighting.
If you are going to be switching between indoor and outdoor, do the same for the B button above and set it's white balance to the exterior light color temp. that way you can just switch between A and B when you are moving fast between interior and exterior shots and have the correct color temp.
You could always leave the switch on preset, and hit the AWB button on the front to switch from 3200 to 5600, but remember not all light is either 3200 or 5600, that is why we use the A and B settings and get the White balance for the exact color temp of the space being shot in.
Jul 25, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
In daylight every photo whites out can you help
Take a look at the settings on your camera. There should be a way to change the white balance. White balance is used when you shoot a photo in the direct sunlight. Have you ever noticed the whites in a picture suddenly look blue? This is because your white balance is turned off or not in the correct mode. The same goes for your pictures that look too white. Take out your camera guide if you have one and look up White balance. You should be able to find the correct settings for the pictures you are trying to take.
Hope this helps.
May 10, 2009 | Olympus FE-330 Digital Camera
White balence
The EOS Rebel K2 is a film camera. White balance settings on digital cameras are an electronic 'adjustment' to the image sensor. In film cameras, the film is the image sensor. So white balance is dependent partially on the film you're using, but more often on the filters you add to the lens to correct for various lighting conditions and light sources.
Jun 13, 2008 | Canon EOS Rebel K2 35mm SLR Camera
White Balance
What is White Balance? The human eye captures white as white, red as red and blue as blue, regardless of whether you are outside under the sun or inside under incandescent lighting. Although this is something that we take for granted, the human eye actually adapts to correct the changes in color under different light sources. In reality, when light sources vary, colors caught as the reflection of those light sources also vary. For instance, films for cameras that use film are designed to capture the most appropriate coloring outside under the sun. Thus when you take pictures under incandescent or fluorescent lighting without using a flash, the colors in the resulting picture may seem strange. Digital camera and digital camcorders are equipped with a handy feature called "White Balance" that corrects the changes in color under different light sources, just like the human eye. One of the white balance settings, "Auto White Balance" (AWB) automatically adjusts to correct the changes in color under different light sources. White Balance and Coloring The White Balance feature on Canon digital cameras and camcorders is set to "Auto White Balance" at the time of purchase. If you prefer different coloring, if you want to adjust the coloring more in detail, or if you want to change the coloring on purpose, we recommend that you change the white balance setting.
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
White Balance
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Balance Function
This function is useful when you need more precise white balance than the Preset White Balance can provide. To set the optimum white balance for the shooting conditions, point the camera at a white object under the light source that you want to use, and press the OK button to set the white balance.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Kodak EasyShare Z760 Digital Camera Logo
Top Kodak Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Kodak Camera Expert? Answer questions, earn points and help others
