Question about Insignia 32" 720p Flat-Panel LCD HDTV
I have an Insignia 42" LCD HD tv model# T420HW04.
I have an Insignia 42" LCD HD tv model# T420HW04. The colors are way out. Blue hair, etc. Tried all adjustments and reset button. Tried connecting to another working cable source with same result. This started after coming home from vacation. There was a lightning storm here while we were gone but didn't appear that power had been out. I cannot locate a wiring diagram online. I see nothing obvious internally like a damaged capacitor or resistor. Any ideas? Neil
Posted by Dennis Neil Wright on
    Top Expert:
  • Insignia Master
  • 76,466 Answers
It sounds that the white balance adjustment is misaligned. You have to enter its service mode to re-adjust this. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Without any knowledge in electronics, nobody cant do this adjustment correctly. Enter the service mode, if you're confident.
Posted on Oct 28, 2013
5 Related Answers
Anonymous
SOURCE: Insignia LCD HD tv with "No Signal/VGA input"
Your Television need to be reset. Take the back off carefully, locate your picture lamp, somewhere in that area should be your reset button. Your television needs to be powered on, so be very carefull not to touch anything other than the reset button, hold the button in until your TV goes blank, then release and put your cover back on. That's it, your TV should be back to normal. You might have to run your setup again.
Posted on Apr 18, 2008
Anonymous
  • 57 Answers
SOURCE: Insignia TV no audio on non HD channels via HDMI cable.
have you tried to change the audio settings to HDMI on tv? when u have HDMI hookd up u have to change the audio to HDMI also
Posted on May 31, 2009
ripleymojica
Mando Mojica
  • 643 Answers
SOURCE: Insignia 42 LCD TV Blurry Picture. Computer
tuner is going bad use a cable box that has hdmi or component video to bypass the tvx tuner
Posted on Jul 02, 2009
Anonymous
  • 3 Answers
SOURCE: sound but not picture - capacitors look okay, hair dryer didn't w
Insignia NS-32LCD has problems. Has sound but no picture. Back light is present as well as green and purple vertical lines. I replaced power supply and PC BOARD 782.32FB18-520A no help. Flashlite test showed nothing. Any suggestions???
Posted on Aug 14, 2009
Anonymous
  • 87 Answers
SOURCE: insignia tv will not powerup
Nothing at all? Does the screen seem to go from dark black to a lighter shade of black?
If the screen appears to stay on the darker shade of black then it is broken, and needs to be sent for repair. ( ie the screen isnt powering on when the tv is and there is nothing you can do without opening it.
You might try unplugging all cables and leaving it off with no power for a day This is in effect performing a factory reset.
and this may sound stupid and patronizing but is the TV being taken out of standby mode and actually switched on?
Nick
Posted on Sep 09, 2009
Reset color color is not right to much blue
You may have to go through settings and do resetting if necessary to factory default and try.
Aug 19, 2012 | Westinghouse W4207 42 in. HD-Ready LCD TV
Insignia tv light blinking red and blue
you have a faulty parts inside..try to disconnect one by one the supply of all board until you get stable lights..
Jun 14, 2012 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
The letters have worn off HD tv insignia remote.
The owner's manual and other useful downloads can be found at InsigniaProducts.com. Just search for your TV model number!
Mar 07, 2010 | Insignia 42" LCD Flat-Panel HDTV
Why is there a half second lag on my new insignia lcd tv when i play my xbox 360 in hd and not in hd also? is there a setting i can adjust on the tv to eliminate this problem?
Try setting your TV to "Game Mode" and/or turning DCM off. A copy of the owner's manual can be found on InsigniaProducts.com with additional details, just search for your TV's model number.
Jan 31, 2010 | Insignia 42" LCD Flat-Panel HDTV
Insignia 42" 1080p flat panel tv
you have lost your chroma (color) circuit the sepia you are seeing is just the black & white picture black and, white is adjustable from red to blue to green tint so; your sepia is an overloaded red circuit i could fix this but, i'm here and, you're there so take it to a serviceman it should not cost much more than $100
Apr 30, 2009 | Insignia 42" LCD Flat-Panel HDTV
Philips LCD HDTV -- color problems
I am having the same issue. I believe the issue to be somewhere in the transition between HD channels and non HD channels. A work around is to switch the input to another input such as DVD and then switch back to your cable input (mine is the HDMI input). I'm probing the web looking for why this happens and if there IS a permanant fix.
Nov 19, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Insignia 32" 720p Flat-Panel LCD HDTV Logo
130 people viewed this question
Top Insignia Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
