I have a maytag two door fridge it's not working the fan is working but it's not getting cold fridge or freezer can you help me sometimes it tries to cut in makes some kind of sound for a couple of sec and stops again
Your refrigerator is on a re-call list with Maytag.
Contact Maytag for a free repair.
What are the last 2 letters in your serial number?
The MT in the model number indicates recall. The serial number may not be in the list.
This is going to be a bad start relay. That is what was wrong with the recall fridges too.
Maytag has been using bad relays for awhile.
Although it is not on recall. The start relay is most likely the problem.
Please rate this solution after they do the repair.
Thank you.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
not cold.
it is not running cold.
wow. thank you! i am going to give them a call. i will let you know how it goes.
i called them and they said that they have had some models go on recall recently but that this was not one of them?.?. They set up a time to come look at it though.
the last 2 letters in the serial # are EL
Is it not running or not cold?
