GE JES1142SPSS 1.1 cu. ft. Countertop Microwave Oven with 1,100 Cooking Watts, Auto/Time Defrost, Instant Logo
Liz Dorland Posted on Oct 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you stop, reset or change the remaining time on the Timer on the GE JES1142 microwave? Pressing Clear/Off does nothing. Do you just have to wait for the timer to run out? Manuel is wrong even on how you start the timer (you have to press Timer again, not Start).
  • Matt Pelphrey Jan 24, 2014
    Press and hold the Timer button for 3-5 seconds.
Matt Pelphrey
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 24, 2014
Matt Pelphrey
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
342
Points
Press and hold the Timer button for 3-5 seconds to reset.
William Miller
Level 3:
  • GE Master 9,179 Answers
  • Posted on Oct 28, 2013
William Miller
GE Master
Level 3:
Answers
9179
Questions
Helped
4479401
Points
21747
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
1 Related Answer
Oloyede Monsuru
  • 1468 Answers
  • Posted on Sep 11, 2010
SOURCE: Team, I have a GE JVM1630 BK01 Microwave Oven,
hello,
There is no reset button for this type of problem to be properly solve.
this type of problem can be view from two angle here below
1) From the wall power supply connection
2) from the oven wires connection to the panel or unit control
What this could indicate from your explanation is that there has been a bring of wire from the power control connected to the element (heater), what you are to do to solve this problem carefully, is to carefully unscrew the oven then trace the wire from the main power supply down to the control switch (panel or unit) after you most have unplug it from power supply to see if there is any of meant wires around if you are un able to trace any loose/bad wire then couple it back to it position and trace the problem to the main power supply from the wall mean that a partial contact from the wall unscrew it with a screw driver (technician tools )fix it up and then couple it back with this the problem of continuous will be solve.
thank you and thanks for using fixya.
How can I clear pause off my GE microwave
On most GE microwaves the Timer function can be cleared by simply pressing the Clear button once or twice. On some models pressing and holding the Clear or Timer buttons will clear the function.
How do I clear the timer fuction on my GE profile microwave
hi Donna.
this is all i could find out.
How to clear timer on GE microwave? Clearing the Timer on the Microwave. On most GE microwaves the Timer function can be cleared by simply pressing the Clear button once or twice. On some models pressing and holding the Clear or Timer buttons will clear the function. Review the Owner's Manual for model specific directions.
Clearing the Timer on the Microwave - Products - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?contentId=16868 Search for: How to clear timer on GE microwave?
or this.On most GE microwaves the Timer function can be cleared by simply pressing the Clear button once or twice. On some models pressing and holding the Clear or Timer buttons will clear the function.
How to clear the timer fuction on my GE profile microwave Google Search
Microwave jes1142
If the timer counts down and nothing else happens, the secondary interlock switch is bad. This switch completes the cook circuit and this is why it doesn't run. You need an ohm meter to diagnose and find the right switch. Switch failure is caused by opening the door when it is in cook mode. Push the stop button first before opening the door and this failure will cease to occur. BE CAREFUL !!
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
1helpful
Microwave GE model JES1142 won't start nor even light up when plugged in.
I would remove the outter shell and check the glass fuse inside next to the power converter.
72helpful
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Team, I have a GE JVM1630 BK01 Microwave Oven, yesterday after we finished heating up some food we shut the microwave door and it remained running even though it the programed timer ran to zero. We tried...
hello,
3helpful
Sanyo microwave clock reset
This is the generic instructions to set the clock. I have visited the sanyo site to aquire a owners manual with no success in locating one. This being said, here are the instructions.
  1. Unplug the unit for a minute then plug unit in.
  2. Press the clock (clock/timer) button once.
  3. Using the keypad, input the time you wish to set.
  4. Press the clock (clock/timer) button once.
  5. Press the stop/clear button, Time should remain.
Hope this works, if not, let me know.
Please take the time to give this solution a fix ya rating.
clarkco
GE JVM240 microwave - shut door, fan runs,can't set timer or cook
The "main" relay on the control circuit board is stuck (shorted) and needs to be replaced.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
No heating, no clock, no timer, otherwise fine!
One of your door interlock switches is defective . I would suggest having it repaired by a qualified repair tech in your area.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
