Question about Sony PlayStation 2 (PS2) Console
Options menu dead
My Ps2 can play games, that's for sure. But the options menu does not respond to anything. (i.e. analog, pressing 'x' and triangle) Because of that I'm not able to clear up memory cards, change languages, set the time, and more. My time is way off, and I really want to know how I can get my Ps2 to respond again. Thank you for your time. ;)
Posted by balloonsalam on
Louis Magpantay
  • 374 Answers
Hi!there,
well! you can't activate what you want because the button "x" and " triangle" are the function key to move on but because of the pads inside your analog controller on "x" and "triangle"are worn out,there is carbon contactor on buttons has fade out,when ever you press x button no connection is conducting your analog controler.you can change setting on analog controller between x and square depend on you,go to configuration then on dual shock controller menu reset function button,you select a key that will change the function key.
or maybe replace your dual shock controller is the best way,
have a nice day,don't forget to rate me,thank's
Posted on Apr 29, 2009
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
Tip
Try this to play DVD movies on your PS2 if it wont play DVD movies.
If your PS2 works fine with Games and just wont play any DVD movies at all.Then you should try this trick to play movies on your PS2:
  2. Menu screen will appear like:894e4e5.jpg
  3. Press the ps_b_triangle.gif (triangle) Button to enter Version Information Menu that looks like3aef030.jpg
  4. Highlight the Play Station Driver as above and again press ps_b_triangle.gif (triangle).
  6. Highlight the Disc Speed as above and press ps_b_x.gif button,to enter Disc Speed Menu
Be patient and wait till the movie plays itself.If your lens is good then it will play DVD in first go else try again till it PLAY your DVD movie.
Thank you!
on Nov 29, 2009 | Sony PlayStation 2 (PS2) Console
How to fix my playstation 2 that won t read grand theft auto san adreas
Your console is an old one,and your lens too is probably weak.Try cleaning your PS2 lens Watch Video at end of solution to clean your PS2 at home....
You can also follow these steps to make your PS2 to play GTA San Andreas:
  2. On menu screen go to [options] by pressing 'triangle' button.
  3. A new screen will appear select by pressing 'X' [DISC SPEED]and set it to [FAST]
  4. Then insert the game disc.
  5. Turn off your PS2.
  6. Press and Hold the [Reset Button] till the blue light turns on.Release the Reset button and press it again.
It will take a bit more time to play game,but first i recommend you to clean your PS2 lens,watch this video.
I've got something else to add.......you can follow above steps to play DVD movies if your PS2 dont play any.....!!!
Nov 19, 2009 | Sony PlayStation 2 (PS2) Console
My playstation is unable to read dvd movies do i need some kind of cleaner for it and what type?
dOn wOrRy all u hAv to do is
to turn on uR pS2 witthout puttin a DVD oR aNy diSc........
on mEnu screen gOto [options] by pRessing 'triangle' button.........
a new screen will appear select by pressing 'X' [DISC SPEED]....n sEt it to fAst
.....then insert the DVD movie........tURn off PS2....
press n hold the reset button till the blue light is turned on
......release the button and press it again..............
it wOuld take a little tYm foR uR DVD movie to be loAded........
be patient till the movie plays it self..............
If uR DVd still wont play then you should clean your PS2's lens Watch this video.....!!!
Oct 16, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 won't play dvds anymore but will play ps2 games just fine. What happened and can it be fixed?
This is one of the most common problem faced by old thick pS2..........but dOn wOrRy all u hAv to do is to turn on uR pS2 witthout puttin a DVD oR aNy diSc........on mEnu screen gOto [options] by pRessing 'triangle' button......... a new screen will appear select by pressing 'X' [DISC SPEED]....n sEt it to fAst.....then insert the DVD movie........tURn off PS2....press n hold the reset button till the blue light is turned on......release the button and press it again.............. it wOuld take a little tYm foR uR DVD movie to be loAded........be patient till the movie plays it self..............
Sep 27, 2009 | Sony PlayStation 2 (PS2) Console
PS2 will not play DVDs
hEy i hAd the sAme pRob...............dOn wOrRy all u hAv to do is to turn on uR pS2 witthout puttin a DVD oR aNy diSc........on mEnu screen gOto [options] by pRessing 'triangle' button......... a new screen will appear select by pressing 'X' [DISC SPEED]....n sEt it to fAst.....then insert the DVD movie........tURn off PS2....press n hold the reset button till the blue light is turned on......release the button and press it again.............. it wOuld take a little tYm foR uR DVD movie to be loAded........be patient till the movie plays it self..............
Jun 13, 2009 | Sony PlayStation 2 (PS2) Console
Guitar Hero Metallica Wont play on my Ps2
okay, try this: 1. Start up PS2 with no disc 2. select 'Browser', press triangle. 3. select 'Console', press triangle. 4. select 'Diagnostics', press X, select 'ON'. 5. press 'O' to back out of this menu. 6. select 'Playstation Drive', press triangle. 7. select 'Disc Speed', press X, select 'FAST'. 8. press 'O' to back out of menu. 9. turn off PS2. 10. insert disc. The Diagnostics should run and automatically adjust your PS2 to play the game. I got this "FIX" from someone who had the same problem. Hope this helps :D
Jun 09, 2009 | Sony PlayStation 2 (PS2) Console
We just purchased Guitar Hero and when we put it in our PS2 it dont spin the disk??
Here's what I did to fix the same problem on my PS2 (Slim model # SCPH-70012). This should work for all models of PS2's. (Slim or Fat). Sony says all models can read a dual layer disc. If the fix doens't work then you need to send in your PS2 for service.
1) Start up the PS2 with no disc in it.
2) Highlight the 'Browser' menu and press the 'green triangle' button.
3) Highlight the 'Console' menu and press the 'green triangle' button.
4) Highlight the Diagnostics menu and press the 'blue X' button and select 'ON'.
5) Press the 'red O' button to back out of this menu.
6) Highlight the 'PlaystationDrive' menu and press the 'green triangle' button.
7) Highlight the 'Disc Speed' menu and press the 'blue X' button and select 'FAST'.
8) Press the 'red O' button to back out of this menu.
9) Turn off your PS2.
10) This step is optional.......I blew into the main unit to loosen any dust out of it and then carefully used my shirt to wipe across the lens at the back of the drive. I'm not sure if this mattered or not. Since I did this in conjuction with the above steps I can't say if this is needed.
11) Insert the disc and turn the PS2 back on. The diagnostics should run and automatically adjust your PS2 to play the game. I was amazed! Mine loaded right up after several previous days of nothing.
12) I checked the settings after the initial load and the Diagnostics and Drive speed reset to normal so it must be a one time run thing. My game has loaded everytime since and I haven't had to re-do the settings at all.
I hope this works for you too!!
Dec 30, 2008 | Sony PlayStation 2 (PS2) Console
PS2 Star Wars Force Unleashed Game won't run
Another thing you might want to check is the system settings on the PS2. Start the PlayStation 2 console with no disk inserted in the drive. Upon loading to the main screen which states "Browser" and "System Configuration", press the X button on the controller. You will see five categories, highlight the PS Driver category, and then press the Triangle button once. Verify that both options within say "Standard". If they do not, then please use the steps below to change them.
- Use the D pad up and down to select the option that needs to be changed.
- Once the option is highlighted, press the X button once
- Use the up and down keys on the D pad to change the option to the Standard setting.
- Press the Circle button once to confirm the change
Next, use the D pad to select System Configuration, then press the X button. Using the up and down arrows on the D pad, cycle through the options on the screen and confirm that they read as follows.
Digital Output - Off
Component Out - RGB
Language - English
Screen - Full (This toggles the letterbox functions of the console, and may not be fully supported within the functionality of some games).
If any of the options are different from what is stated above, then, with the option highlighted, press the Triangle button. Use the D pad left and right to select the option that matches what is listed above. Once the correct setting is selected, press the Circle button. Once all the options are set as listed above, press the Circle button to return to the Main menu.
You may also want to try enabling the Auto-Diagnosis feature of the PS2, which will allow it to auto-detect the best settings to use when playing DVD's.
To Activate the Auto Diagnosis
- From the Browser and System Configuration menu.
- Press the triangle button to select Version.
- Highlight the Console from the list and press the triangle button - this accesses the next menu option.
- The Diagnosis will be highlighted.
- Press the X button to access the options available.
- Highlight "ON" and press the X button to affect the change
Dec 14, 2008 | LucasArts Entertainment Company Star Wars...
Disc read error
Disc Read Error generally means that the game disk cannot be read by your console.
Reasons for Disc Read Error
1. Disk surface scratched or smudged.
2. Disk surface dirty.
3. Lens surface dirty.
Here is what you can try doing.
1. Check the game disc for any scratches or smudges on the surface of the game disc, try to clean them off by using a non-abrasive cotton cloth.
2. If the PS2 console is lying down, please set the console to on its side or if it's on its side set it to flat position, restart the console and then try game again. Always ensure the PlayStation 2 is in a cool, well ventilated place.
3. Remove and reinsert the Memory card of your PS2, restart the console then try running the game again.
Other troubleshooting that you can try.
Change the Disc speed of the PS2 DVD and then try again.
Start the PS2 with no disc in a drive. Press the "triangle" button on the controller.
Use the up and down buttons on the controller to select "Playstation Driver” and press the "triangle" button on the controller.
Select Disc speed. If it is set to "Fast," select "Standard"; if it is set to "Standard", select "Fast" and press the "X" button on the controller. Press the "O" button on the controller. Insert the game disc and restart the PS2. Try running the game again.
Turn the Diagnosis On for PlayStation2 to auto detect the best settings.
From the Browser and System Configuration menu. Press the triangle button to select Version. Highlight the Console from the list and press the triangle button - this accesses the next menu option. The Diagnosis will be highlighted. Press the X button to access the options available. Highlight "ON" and press the X button to affect the change. Restart the console and try the game again.
If the above steps does do not solve the error then you would probably have to replace the disc.
Note: If you are using the Slim version of PS2 make sure that the console is properly ventilated and that it should always be in the standing position, as the slim version of PS2 no fan or any other cooling unit unlike the normal PS2.
Oct 13, 2008 | Video Game Consoles & Games
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
