I bought a new ion rechargeable battery because i thought it was the battery not charging it turns out that it is the dock or the charging mechanisims on the camera? what can i do?
Hello June, This sounds pretty easy, I repair these cameras. It sounds like you have a problem with the adapter that plugs into the wall outlet. Remove the battery from the camera and plug the a/c adapter directly in to the camera and try to power on the camera,if it powers on then the problem is the dock,if it do not power on it is the a/c adapter.
Best Regards, Russell
SOURCE: My Kodak EasyShare DX4530 camera dock not charging batteries.
There was an issue with the 4000 series and the NiCd batteries I remember that had to do with the contacts in the camera. The charging circuit is in the camera so you have to make sure that the battery contacts are clean, both on the battery and in the camera.
SOURCE: Camera will not stay booted up
It seems that the Milli Amps on your rechargeable batteries are to low you will notice on each battery it will show the amplitude purchase a higher amplitude.
SOURCE: how to recharge my batteries on the Kodak dock
Here is the manual. it tells you how to charge on the first page.
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00839/V1073_V1273_UG_GLB_en.pdf
Or yo ucan charge like this.
http://www.kodak.com/global/en/service/help/support/usbCharging_V1233_V1253.jhtml
Good luck and please rate
SOURCE: Is it the DX 4530 camera, dock or batteries that aren't working?
If the batt aren't KODAK there might be a problem.
I will suggest an alt. charger.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
