Question about JVC RX-6018V Receiver
Overload 6042 speaker - JVC RX-6018V Receiver
Posted by Amauri rodriguez on
My receiver started making popping sounds and cutting out for seconds at a time. Checked all connections can't figure what's wrong.
It sounds to me like you have a problem with one of the amplifiers and the speaker protection is activating. If you are playing at a low volume setting and this is happening, the likelyhood is that one of your bias levels is out of tolerance. If you don't know what you are doing, get someone who does to check the DC voltage on your speaker outputs without the speakers connected. The bias control should be set to 0 volts on the speaker outputs.
Mar 04, 2015 | JVC RX-6042 Receiver
Hello. I have a JVC RX-6042 and when I play music, DVD's or any other sound, it cuts out, either after 5 seconds or 5 minutes, it always changes. It cuts out faster at higher volumes. A few months ago it...
Generally speaking, an amp protects itself from heat, shorts and overloads. I'm thinking heat.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 03, 2011 | JVC RX-6042 Receiver
Receiver shows overload on the screen during play or when the volume increases during commercials and then shuts down.
Jan 28, 2011 | JVC RX-6042 Receiver
When I turn it on, it says Overload and then shut off
Try disconnecting your speakers. Then see if the unit displays overload. If it does, then the finals in your Amplifier have gone bad and will need service. If the unit comes on and there is no error, you most likely have a bad speaker.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Aug 18, 2010 | JVC RX-6042 Receiver
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
I am having problems getting optimum sound out of my back speakers????why? there is sound but very little????i have 85 watt (2) in back of room can u suggest how to get optimum sound from back...
Define optimum.
If it tests out in the speaker setup then it's probably just fine. There usually isn't much program material directed to that speaker.
Mar 19, 2010 | JVC RX-6042 Receiver
Overload flashs
there will be 6 amp circuit in your receiver. you can't unplug them one by one. with a multi-meter you may be able to find the shorted channel. (most JVC receivers use discrete circuits instead of an output IC) Check for shorted transistors attached to the heat sink. You will possibly find some open resistors also. Generally this is a job for a pro.
Feb 26, 2009 | JVC RX-6042 Receiver
Sub woofer
first confirm power cord is firmly inserted----change cable between sub and receiver--repeat your setup for speaker.
Jul 28, 2008 | JVC RX-6042 Receiver
Overload
The audio amplifier IC of your device are damaged you gotta send to a repair center.
Jun 04, 2008 | JVC RX-6042 Receiver
JVC RX-6018V Receiver Logo
Top JVC Audio Players & Recorders Experts
xxxxxx xxx
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
