GE 98669 Easycam Pro Webcam Logo
e
edward vogel Posted on Oct 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I put CD in pc yet will not load .windows screen says cannot locate driver
patrick
Level 2:
New Friend:
  • Expert 64 Answers
  • Posted on Oct 28, 2013
patrick
Expert
Level 2:
New Friend:
Answers
64
Questions
0
Helped
14198
Points
139
Download new driver and install
1helpful
I have formated my pc. I not have a mother board cd. I want down load mother cd now.
You can download the drivers for your laptop from the links below
Sound Notebooks ADI SoundMAX Audio Driver for Microsoft Windows XP
Display S3 Twister-K Graphics Driver for Windows XP
LAN
Mobile Intel PRO/100 NIC Drivers
Modem Conexant 56K ACLink Modem Driver for Windows XP
Full Drivers Page
Download the drivers from the links above, and save it to your hard drive Simply run one by one the downloaded files, it will ask you for the temporary location for extracting drivers, save (e.g C:\Swsetup\R10247) save the drivers and the setup will install the drivers automatically just follow the on-screen instruction while installing.. Good Luck !
If you require more assistance feel free to reply to this post,
Thanks for Contacting FixYa!
Regards-BA
2helpful
2answers
Need a password
Dear i have send some instruction of need a password.
please follow the instructions.
and you receive a password.
Thanks.
1. Download a free demo version of Windows Key (to reset a "Demo12345" password for a trial) or buy an instant download online (to reset an unknown password)
2. Run the downloaded file to install Windows Key. You can install Windows Key on any PC you have access to
3. At the end of the installation process enable the "Run Windows Key" check-box and click the "Finish" button. Windows Key will be launched automatically
4. Create a password reset CD, USB Flash drive or a driver floppy following the instructions below:
Using a Windows Key bootable CD 1. Click the "CD image" link
2. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. The file is usually located in the 'I386' folder of the Windows Setup CD. Click "Next" (Don't have any Windows Setup CD? Request a Windows Key .ISO download)
3. Enter you name and set your own password for the bootable CD (you may set an empty password). Click "Next"
4. WindowsKey.iso file is created
5. Insert a blank CD, specify your burning drive from the list and click "Next"
6. Windows Key password reset CD is ready
What should I do next?
7. Reboot your system with this CD
8. Windows Setup process starts
9. After all the required files are loaded from the bootable CD, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable CD
Continue to step 14*
Using a Windows Key bootable USB Flash Drive 1. Click the "USB Flash Drive" link
2. Connect a blank USB Flash Drive. Click "Next"
3. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. Click "Next" (Don't have any Windows Setup CD? Request { /iso-request.htm } a Windows Key .ISO download)
4. Enter you name and set your own password for the bootable USB Flash Drive (you may set an empty password). Click "Next"
5. Windows Key password reset USB Drive is ready
6. Reboot your system with this USB Drive. To reboot your PC with USB Flash Drive you may need to set the following options for the BIOS Setup Utility: after rebooting your PC please press "Del" or "F2" to run BIOS Setup Utility, go to the "Boot" section and press "F6" to move the "Hard Drive" device up, press "Enter" on the "Hard Drive" option and press "F6" to move the "USB Drive" device up. After all the changes are set please press "F10" to exit and save the settings
7. Windows Setup process starts
8. After all the required files are loaded from the USB Drive, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable USB Flash Drive
Using a Windows Key driver floppy 1. Click the "driver floppy" link
2. Insert a blank floppy into the floppy drive and click "Next"
3. Enter you name and set your own password for the driver floppy (you may set an empty password). Click "Next"
4. Windows Key creates three files on the floppy: winkey.sys, winkey.inf and textsetup.oem. The driver floppy is ready What should I do next?
5. Insert Windows Setup CD or bootable floppy and reboot your PC
6. Windows Setup blue screen appears
7. Press "F6" when Windows Setup prompts for additional drivers at the bottom line of the blue screen
8. Windows Setup continues loading required files from the bootable CD or floppies
9. Windows Setup prompts you to press "S" to specify additional drivers. Press "S" and insert the Windows Key driver floppy
10. Press "Enter" to specify the "Windows Key" driver
11. Windows Setup loads the files from the floppy drive
12. Windows Setup continues loading the files from the Setup CD or prompts you to continue with the rest of the bootable floppies
13. After all the required files are loaded from the Setup CD or bootable floppies, Windows Key starts working. It displays your license info and asks to enter the password that you set for the driver floppy
Boot Mode 14. Please enter the password that you have set for the Windows Key bootable media
15. Select the Windows installation to be unlocked
16. Windows Key asks: "Undo Windows Key changes? (Y/N)". Press "N" if you want to reset the password or "Y" if you want to leave the original passwords and cancel the program changes
17. Select the account to reset the password for
18. Windows Key asks: "Reset 'account_name' password? (Y/N)". Press "Y" to reset the password or "N" to leave the original password
19. Windows Key asks: "Reset password for another account? (Y/N)". Press "Y" to reset password for another account or "N" to quit Windows Key
20. Remove the Windows Key bootable media and restart your PC.
2answers
I bought lenovo G550 last week. It came with Windows Vista. I want to install Windows XP on it. I have found that lenovo has driver for windows XP so that will make my life easy :-) But when I try to...
you are most likely getting a BSOD with a stop error code of 0x0000007B which is caused by the Windows XP CD that you are using doesn't have the SATA Hard Drive controller driver needed to recognize and utilize the hard drive. If Lenovo has XP drivers for this model then they should have a SATA driver (roughly 394k) that will need to be loaded FROM A FLOPPY DISKETTE during the boot to XP. (XP Requires the driver to either be slipstreamed into the CD or loaded from a floppy diskette. Trying to load the controller driver USB or a different CD will not work)
http://www.digitgeek.com/how-to-slipstream-sata-drivers-into-xp-cd/
2answers
Windows unable to locate cd drive
you reformat your hard disk and install guienuine microsoft window xp your problem will be fix
2answers
How to reformat my gateway 400sd4 laptop?
If you are planning to install windows after format, then u can do the formatting during the windows installation procedure. Insert the CD, boot from it. Otherwise you would need a Linux live CD
2answers
Hello, Anybody Please help me! I just bought compaq laptop with preinstalled Xp. I want to use Xp and because of some problem in existing XP, I would like to re-install XP professional. When I put CD and...
Serial ATA (SATA) drives are the latest in the hard drive fashion and, in theory, installing Windows on the drive should prove relatively simple. The problem is that Windows XP doesn’t contain the necessary drivers to allow windows to see the drive so that Windows can install it.
I found the procedure below on an XP support website. I have not tried this procedure but after reviewing I fairly certain this should work for you.
1/ Copy the SATA drivers (these can usually be found on your pc or motherboard's support disk. Usually these consist of PIDE/SATA Folders and TXTsetup.oem files. Alternatively they may have been supplied on a separate CD that accompanied your SATA drive, assuming you purchased it separately from the pc.)
2/ Insert the Windows XP CD (full retail version – you should not need to follow these instructions if your pc came with a recovery disk) into the CD-ROM and Reboot your PC
3/ Watch carefully as the Windows XP installation progresses and look carefully at the text at the bottom of each screen.
4/ At the Windows Setup Screen (this should be the second screen after installation starts) you should see, at the bottom of the screen) a message saying “Press F6 if you need to install a third party SCSI or RAID driver.”
5/ At this point press the F6 button
6/ When the next screen appears press S to specify an additional device
7/ Now insert the floppy disk containing the SATA drivers into your floppy drive
8/ Windows will next ask you to select a driver from the provided list
9/ Select VIA Serial (or whichever controller your motherboard supports) ATA RAID Controller (Windows XP)
10/ The SATA drivers on your floppy disk should now load
11/ After the drivers have loaded Windows XP will recognise your SATA hard drive and you can continue installing the Windows XP operating system
CD/burner is gone and Wont load anything i put in.
Try using device manager and deleting the CD from it, then reboot and let windows do its thing with intalling it again. Let me know if windows does NOT try to reinstall the CD drive or you get any error messages
Top GE Computers & Internet Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
