Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Printed pages have white lines
Everytime i print the paper comes incompleate white lines lines in between rows
please send coments hpw to clean my printer i have cleaned the print head, i have aligned printer...i dont know what else to clean..please help
Posted by sgarcia414 on
  • sgarcia414 Apr 27, 2009
    I JUST DID...STILL DOING THE SAME..i adjusted on the printer only from something else can i try..it be posible that the printhead may be dammage...
Anonymous
  • 67 Answers
Adjust the properties of your print mode the default is normal change it to best. the printing speed will change but the print quality will be good.
Posted on Apr 27, 2009
Black marks on the printing
You could have a build up of ink on your rollers, and as the paper is pushed through it is leaving marks. It could also be causing your ghosting effect or double lines. By having your printer cleaned by a certified technician it should reslove your issue.
Jun 09, 2010 | Epson Stylus Photo 1290 InkJet Printer
Copies leaves lines when put through the feeder,but not on the glass .......have cleaned and sprayed air can everywhere I can think of The Hp Printer is HP 3055 All in One printer
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | HP LaserJet 3055 All-In-One Printer
Getting a black strip in copy mode on X6575 lexmark printer. No line in print or test mode
Most likely a page was scanned with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
Mar 16, 2010 | Lexmark X6100 Flatbed Scanner
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
I have a black line showing up on my faxed documents. I have opened it up, changed the film and re- set it, but the problem persists. The machine is about 5 years old.
Feb 07, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
I had a paper jam and now everytime I print there are lines
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Feb 12, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Printer sends out extra page everytime I print
either your paper size settings need to be adjusted in the software, or your setup has included a seperator page.
Jan 27, 2009 | Office Equipment & Supplies
Incomple text printing
if your using microsoft word, try to click file then page setup and then click paper..choose the right paper size,then click margin, increase the `right` value.
GOOD DAY!!!
Sep 13, 2008 | HP DeskJet F380 All-In-One Printer
Epson Photo R265 Lines every 2.5 cm
check if those lines matches the positions of the rollers inside the printer - you can see some of them by opening the cover
Dec 24, 2007 | Epson Stylus Photo R340 InkJet Printer
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
363 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
