When I start the wash cycle the agitator starts before the water as the water is filling the washer it is agitating and then when the washer gets full and the water shuts off it will only wash for about a minute and then start spinning out. When it gets to the rinse cycle and is full of wet clothes the agitator starts first again. Even though I have the 2nd rinse shut off it still starts filling again.
George Scott
    Master:
  • 789 Answers
Heck your warranty--sounds like the cellonoid is sticking
Posted on Aug 02, 2017
5 Related Answers
Anonymous
  • 163 Answers
SOURCE: washer fills up but won't agitate
get your screw driver and lets start.. first unplug the machine from the outlet, you have to access the water level sitch so remove the tab and there is the bandidt, knock him with the screw driver and if this not funcion replace it..good luck I dont tell you to check the thin hose in the water level sitch becouse you said its fill all right.
Posted on Aug 06, 2006
Anonymous
  • 9 Answers
SOURCE: Frigidaire washer won't agitate
Probably a stripped gear in the transmission.
Posted on Dec 23, 2007
Anonymous
  • 4 Answers
SOURCE: shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Posted on Sep 02, 2008
Anonymous
  • 1028 Answers
SOURCE: Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Posted on Oct 25, 2008
Anonymous
  • 20 Answers
SOURCE: Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Posted on Jan 19, 2009
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • 0helpful
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
  • 1helpful
    Agitator starts at begining of cycle before washer is full
    Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
    Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
    After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
    Quentin
    1helpful
    Kenmore 80 series washer. Agitates immediately and does not fill
    it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
    1helpful
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    3helpful
    2answers
    Ge top loader washer agitator does not work
    To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
    Washer will fill with water but the agitator won't spin.
    No agitation or spin in any cycle? If so and the machine will drain check the coupler.
    Agitator always moving
    The inner tub on some machines does rotate very slowly while filling to assist with the even distibution of the load. If the agitator is turning back & forth while in fill mode, you could have a timer or transmission problem. You need a tech.
    Washing Machines Logo
    Top Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
