Question about Ariston Technologies Washing Machines
My ariston washing machine model AVF 109 is flashing fault code F01 is this something to do with the heater? Thanks
Chris Huff
    Top Expert:
  • 6,289 Answers
Https://www.needapplianceparts.com/aristonerrorcodes.aspx.
Posted on Dec 16, 2018
5 Related Answers
dazmaraz
Darren Moxam
  • 67 Answers
SOURCE: F01 flashes and machine not work.WF860P
motor triac short circuit check motor and module connections, if o.k poss motor fault
Posted on Mar 03, 2008
Anonymous
SOURCE: ariston a1636 washing machine
I have the same problem, did this get solved for you?
Posted on May 18, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: WHAT IS FAULT F01 ON MY WASHING MACHINE WF860
F01 indicates a short circuit motor triac, this is part of the motor speed control, either in the motor, or the control unit, and as such is something you cannot repair yourself.
It means that you will have to call hotpoint unfortunately.
If it is under 5 years old, then you should be able to get it done under the 5 year guarantee.
Plz rate my solution.
Thanks.
Posted on Dec 30, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Thanks.
Posted on Jan 13, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: What does a fault F01 signify on a Hotpoint Ultima
Error code F01 indicates a short circuit motor triac.
Thoroughly check all connections on the motor, the motor plug, and the electronic module board..
Look for a broken wire, or a bad connection.
Please rate my solution.
Thankyou.
Posted on Jan 22, 2010
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Flashing Lights on Washing Machine How to Repair ...
Dec 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
How do I reset washing machine Ariston AR7F105 , error code F-01.
F01 - Main modul, triac on board damaged or components feedback fault
  • Short circuit motor triac on electronic module
  • Check wiring
  • Check electronic controller
Dado
Feb 28, 2015 | Ariston Technologies Washing Machines
Fault comes up as f01
For most models of Indesit (Hotpoint, Ariston) 'F01' states 'motor triac short circuit- check motor and module connections'. Sorry but it looks like a service call ;-0(
If this has clarified the situation for you and/or assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 12, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WF640 - What is Fault code F01 please?
My list for nearly all of the Indesit (Hotpoint, Ariston) washers suggests there is a fault with the motor triac, the bit that controls the motor speed, sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
John C
Sep 10, 2011 | Hotpoint Aquarius WD640 Front Load...
Ariston AIB16 flashing fault code f-08? can this
F08 Heater relay cannot be activated
this can be repaired cheap its part of the main board
If it works fine with the heater off then i would say that fault appears to be element..the readings you get seem okay, put you meter onto megs and check, with wires off if you get electrical leakage between live and earth...Body....of element, it could be element is heating with no water in machine causing it to burn out..this is a problem with this machine
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Ariston Technologies Washing Machines
Hotpoint Aquarius cycle not finishing with f02 error
Dont think its pressure switch.if sticks one way machine overfills the other brings on heater with empty drum..Could be fauly rinse solonoid valve...Check with multimeter coil should read around3k ohms..good luck
Sep 29, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
I'm after some error codes please guys, It's flashing 2(Reduces Creases) & 4(Time Saver) I've been told that these 'do' mean something, but can I find out what it is....no Any help would be really...
List of the Error Codes I found on another site. I'm getting f04 light 2 (the "wash" light). Looks like you've got the opposite problem with your pressure switch stuck on full (f05).
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
Sep 27, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Thanks.
Jan 11, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Hariston margarita a1324 advantage
hiya
dont remember giving assitance before but i'll try and help you if i can. when the machine starts to click around count how many times the doorlock/on off light flashes as this indicates a fault code. it will usually go something like, flash pause flash pause etc until it flashes quickly then it restarts the fault sequence.
if you could let me know how many times then i'll be able to diagnose the fault quicker.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 13, 2008 | Ariston Technologies Ariston AWD12 Front...
Washing Machines Logo
236 people viewed this question
Top Ariston Technologies Washing Machines Experts
Marvin
Marvin
Harrie
ray gallant
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
