Question about Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine
Troy bilt tiller
I can get my tiller to start in choke mode but when I switch it to run it cuts off every time.
Posted by jmlamb1004 on
  • josh1111 May 11, 2010
    have you checked out the carb for build-up? it may need cleaning. doe sit have fresh gas in it?
james
    Filmmaker:
    Uploaded 5 video answers.
  • 125 Answers
Either the carb needs cleaned or theres a vacuum leak
Posted on May 05, 2009
How do I fix a surging Tecumseh engine on my 1988 Troy-bilt rotor tiller?
Clogged fuel inlet line or fuel filter. It's not getting enough fuel to run
May 09, 2015 | Troy-Bilt Garden
Troy bilt bronco
Check flywheel alignment key for partial shearing causing a slight out of time situation. .
May 27, 2014 | Troy bilt Super Bronco Tiller 208cc
I have a troy bilt pony with a 6hp Tecumseh engine. It's difficult to start and when I get it started I have to leave the choke on or it will die. Also it doesn't run as it should. I drained the...
I recommend cleaning the filter with gasoline if its foam or replacing it if its paper. If this doesn't fix the problem you should remove the carburetor (in between the air filter box and the engine) and cleaning it thoroughly with carb cleaner from your local parts store.
Jun 17, 2011 | Troy-Bilt Pony Garden Tiller
I have an older Troy-Bilt tiller (model & serial # unknown) that when I start it (manual pull) it runs for a second and then shuts off. I checked the spark plug, fuel line and inline filter, fuel, oil...
could be bad coil. does it stay running with choke on? or half on, if so its a gas problem. could be the main jet is plugged in the carb. Or water in the carb bowl. Remove the bowl nut and let some gas run out the put it back in and try it. just guessing as not much info to go on.
Apr 26, 2011 | Troy-Bilt Pony Garden Tiller
Troy bilt rototiller stalls when opening choke
The carburetor will need to be cleaned very good. New needle valve maybe float and new gaskets That should take care of the problem.
Apr 20, 2010 | Troy-Bilt Pony Garden Tiller
How to start a Troy Bilt Tiller
make sure there is fuel and oil in the engine. There should either be a choke lever/setting or a primer bulb. Push the primer bulb, if there is one, or choke the engine. Make sure it is in neutral, and pull the starter. Should be all there is to it. If there is other info that is causing the machine not to start, please tell model number and what you have done in trying to start.
Jan 24, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I have a troy pony 17.5 that cuts off when you engage the blade and the choke is on. what can i do to fix the problem. thank you for any help to fix this problem
does it run ok off choke with blade not engaged can you rev it up ? if not it sounds like the carbs got issues ? if it does check the second wire coming off the igntion coil too the safety switch may be grounding /shorting causing engine to shut off kinda like the handle on your push mower when you walk away and let go of the handle the zone control cable stops the spark and flywheel ? carb rebuilds at your local shop are under $100 well worth it unless youve done it before kit costs like $15
Aug 25, 2009 | Troy-Bilt Pony Garden Tiller
Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Logo
393 people viewed this question
Top Troy Garden Experts
colesmowers
Sheldon Dedek
Dennis Key
Dennis Key
Are you a Troy Garden Expert? Answer questions, earn points and help others
