Pool & Spa Logo
t
todd Posted on Oct 26, 2013
My hydroquip 9000 trips the gfci when it starts now. the heater,pump,blower and everything was working fine till the power went out. when the power came on the spa didn't work? there is a reset button on the hydroquip 9000 it seems like I read it has to be pushed in for 2 min or something? Any ideas How to reset? I don't have the manual.
slingspade
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Oct 28, 2013
slingspade
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
2962
Points
9
If the GFCI is tripping, the reset button will not do anything. If it was fine before the electricity shut off, it is possible that while the pump was not running, water got into the inside of the pack, and that is what is causing the GFCI to trip. An electrical surge may have damaged the GFCI, itself. Those are the two things that might be related to the power going out.
The most common cause for tripping GFCI's are a heater that has a ground fault. A distant second is a bad GFCI. If it starts to run, then quickly trips, it is almost certainly the heater.
5 Related Answers
Anonymous
  • 125 Answers
  • Posted on Feb 26, 2009
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Anonymous
  • Posted on Jun 13, 2009
SOURCE: Hayward H300 Spa Heater will not fire up
try to replace the thermo sensor it is located on the left side of tghe unit and has 3 wires running to it.
Anonymous
  • 83 Answers
  • Posted on Jul 14, 2009
SOURCE: Sta Rite SR400 NG heater with code r=5
You can find an Owner's Manual online at the following site:
http://www.inyopools.com/owners_manual/sta-rite_heaters_max-e-therm.pdf
IF you have tried to restart the heater and received the same outcome, the r5, or S, is a badk control board. Sorry about that one!
What you may want to try is resetting the heater. You will need to put the SunTouch in the maintenance mode. Then turn off the heater, turn off the Circuit Breaker for the heater, wait about 15 to 20 minutes, then reverse the order. Circuit breaker, then heater, then try and start the heater without the SunTouch first. If it works, then try with the SunTouch.
Anonymous
  • 3 Answers
  • Posted on Aug 02, 2009
SOURCE: layz spa pump
same problem I had so I seperated the globe by taking out the 5 screws around the middle then removed the nut from the hole the filter sits on its a strange fitting and must have a special key but I improvised by tapping it anticlockwise using a screwdriver and rubber mallet, once open identify the heater unit (it has a single wire going into it and is fastened to a length of metal pipe) and remove it by loosening the clamps at either side and pull the heater free, once free dismantle the plastic casing on the top of the heater inside you will see the live, neutral and earth wires, you can see the live (brown) wire goes to the water flow switch then the temp switch then the heater all I did was bypass the water flow switch by disconnecting the short wire from it going to the heat sensor and replacing it with the brown wire coming from the mains and it works fine now
Anonymous
  • 5 Answers
  • Posted on Oct 09, 2009
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
1helpful
3answers
Gfci overheat call for service
If you have any clamp on amperage meters, you need to see what the amperage draw on the circuit is when it is running. This will tell you if something is wrong with the pump circuit. It could be anything from a bad capacitor to an impeller obstruction.
EasyPak 1000 Flex-Fit Air Spa Control System. Everything works fine, except, when plug in heater power. Gfci trips. When unplut heater power, everything works
GFCI blows because you have a short to ground. Check your wiring for loose connections and your heater core element.
Mike
May 29, 2017 • Pool & Spa
1helpful
I have a Beachcomber Model 350 hot tub abd the GFCI is tripped and won't reset
You may have a bad heating element. But first make sure you have power to the gfci. (check the braker) You can test this by disconnecting the heater leads and see if it will reset. If it still trips try disconnecting your equipment one at a time, ie. blower, ozone, circ pump, booster pumps. If nothing solves the gfci issue you need to replace the gfci. All of this is assuming you have a blank gfci receptical monted to your spa pack.
If your talking about the 50 amp gfci at the braker box try pushing the braker all the way to the off position then back to the on possition. If it trips right away do the above.
Aug 06, 2013 • Pool & Spa
2answers
GFCI keeps tripping when pump is submerged
Install another GFCI
http://waterheatertimer.org/How-to-wire-GFCI.html
Do not use anything that trips GFCI in water.
Just get another one and be safe.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 30, 2013 • Pool & Spa
1helpful
We have a 2004 Balboa series spa and the breaker keeps tripping what could cause this? Everything has been working fine.
Understand that this information is beingprovided as-is and without warranty or guarantee. As with all electricalcomponents and devices, all work should be performed by a licensed spa or pooltechnician. Serious injury or death can occur if a component is improperlyrepaired or installed.
There are several reasons the breaker can trip. It could bea bad pump, bad heater, GFCI or wiring issue.... Typically unplugging eachcomponent will help isolate which component is causing the trip. It is rare fora board to cause a breaker trip, so if all components (including both legs ofthe heater) are disconnected and the breaker continues to trip then you move onto wiring or the GFCI.
You can find answers to common spa or bath problems online at http://www.balboadirect.com/support.aspx
1helpful
Hello,I have an old jacuzzi vectra II hot tub (1988) 120 volt.the gfci on the unit trips every time the pump is on low speed with the thermostat calling for heat. there is no trip when there is no demand...
hi,
ok so when the pump is on high and the heater is running it doesent trip? you didnt say if it did. undo the heater leads so the pump is isolated completely. run the pump on the control centers gfci and see if it trips. if it does then try wiring directly - with an extension cord to a plug with a gfci in your house and see if it trips the gfci in your bathroom. if no trip inside house then bypass tubs gfci and run it with heater and pump through your bathroom gfci. if no trip then try and replace the tubs gfci, it gets pretty humid in the control center and gfci's have a semiconductor which which do fail after years of rough duty like that. if it trips the gfci in your house with the heater again it has a cracked heater element. craigslist always has old hot tubs and parts. you might have to buy a whole used old hot tub but that may be cheaper than a new heater box.
later
jm
My breaker is conected to a hot tub. tub was working fine in auto mode. Turned on jets and breaker tripped. will not reset can you help me
I am assuming this is a GFCI circuit breaker? If it is it will have a "test" button on the breaker. When you say "jets" i'm assuming you mean when you turn on the blower to make the air bubbles? It could be you have a problem with the blower motor. When you start the blower, it trips the breaker. Be sure the blower is in off position when you reset the breaker. The most common fault though on a spa/hot tub is with the heater. If the element goes bad, and current flows to ground, it will trip the GFCI breaker. Again try and turn all functions off. Reset breaker, and then turn on one at a time till the breaker trips. First the pump, then the heat, then the blower.
Dometic RM2652 RV Refrigerator trips GFCI
Hi!!
Right beside the circuit panel, there is a grill, remove the 4 screws to gain access to the transformer/battery charger. You'll see a double power outlet, one cord is from fridge, the other is from the transformer. UNPLUG Transformer cord and reset breaker.
It will take a couple of minutes for the fridge to change to AC if you have it in AUTO. If everything works fine, REPAIR OR REPLACE TRANSFORMER/BATTERY CHARGER.
Don't forget to rate this answer, Good Luck!!!
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
