There should be a pusher that is attached to a spring. If the spring broke, or the pusher is missing the staples will not stay in place.
If you can locate a model number on the tool, you go to bostitch.com to find the parts you may need
SOURCE: staples not coming out
yes they are, I would double check the guage and shape of the staples for this tool to ensure they are correct. If you give me the model number I will find what guage you need and get back to you.
SOURCE: setting staples too deep
The depth is set by the bumper and the bumper spacer. Are you sure these were put back in? the air pressure only makes a small difference on the depth...
SOURCE: I cant load the brads
You can go to http://www.stanleytools.com/default.asp?TYPE=STATICLEFT&PAGE=Support.htm&LEFT=left_support.htm
Click on Knowledge base and search for your model. I found it but I am unable to attach a copy here.
SOURCE: Need manual for stanley electric stapler model
here is a link to the manual
http://homeappliance.manualsonline.com/mdownloads/f2624d76-9579-4c12-a9f1-22eab6ac3388.pdf
I recommend that you will post your question under the correct category (Stanley Office Supplies) and maybe add more details to it, so it will be easier for Experts to understand the question and answer it.
