Jabra How To Connect to my PC
Running Windows 8.1, I have Jabra Solemate in my bluetooth connections and when I right click "connect", I see it flashes "ready" for a second, but then goes back to "connecting" or going at it another way, I click on bluetooth devices and Jabra Solemate is on the screen and shows it is trying to connect but never does. Also I do push the button on the speaker up to connect.
Posted by Ken Quinn on
Clayton Molle
    Novelist:
  • 138 Answers
Hello
Are you prompted to enter a Bluetooth pairing code? The pairing code for the Jabra Solemate is 0000.
Try disabling the Bluetooth on the Windows 8.1 device and then re-enable it and then try the pairing again.
Posted on Nov 03, 2013
3 Related Answers
Anonymous
SOURCE: Connecting an LG TV to my PC
switch to any setting as long as it is only in 60hz and nothing above that the monitor cant handle it
Posted on Sep 11, 2008
edisonfrelan
edison capulso
  • 113 Answers
SOURCE: Monitor displays breifly then goes to blank screen
try booting up your CPU again, while on its process of booting press F8, then select (something MODE), okay, then when you are at windows environment go to control panel, select display, set your display settings its default or 900 by 600 pixels settings, then if its run okay then change to your desired settings.
Posted on Dec 17, 2008
shamsudeen
SOURCE: IBM Desktop no sound after i tried to connect it to Television
hi Appesh i have ibm think center p4 , there is no sound driver in my
ibm where can i get sound driver. i have downloaded many ac 97 drivers nothing works..
help me plz
Posted on Jan 11, 2010
HOW TO CHANGE LANGUAGE ON JABRA MINI BLUETOOTH
Turn off headset, press and hold power button till light flashes blue and red continously.
Release power button and press it twice. You will hear a Chinese voice prompt.
Press twice again to hear English voice prompt.
Press and hold till it turns off.
Turn it back on and connect to phone.
Oct 12, 2016 | Jabra Solemate Mini Portable Bluetooth...
Major static with bluetooth speaker
With your "new" computer, you get up to 90 days of "free" technical support, via telephone, from Dell. Telephone them.
Feb 23, 2014 | Jabra Solemate Speaker System - Wireless...
How do i connect my headset jabra bt2080 to my laptop hp 620?
I also have laptop hp 620 and the jabra bt2080 which are working through a driverless bluetooth usb dongle v2.0 (China) after installing jabra pc suite_2.5.6. It is under my experiment as at the moment only the mic is working when you start windows speech recognition program. i am trying to get it working as playback device to listen music instead of headphone through jack.
Jul 16, 2011 | Jabra BT2080 Bluetooth Headset
I have got a Jabra BT620s and connected it with usb to Windows 7 64 bit pc. The drivers automaticly were installed and ready to use. But there is no sound trough the headset, only trough the speakers. When...
Does your computer have built in bluetooth? if yes,make sure you press and hold the stereo bluetooth till its steady blue,,not blinking blue. then on your pc, go the bluetooth section in control panel and search for devices. then you should see the Jabra Audio device.click on it to connect to the Jabra and use the passcode 0000. After it connects, the steady blue should now be blinking blue. Then go to control panel, sound and you should see the Jabra there.Right click on it and click on set as default device. Now play any song and see if you still have it playing in your speakers.Let me know if it works.I have the same Jabra and its really works great.Especially when im working out and dont want no wires around me
May 06, 2011 | Jabra BT620 BLUETOOTH STEREO HANDS-FREE...
How can i connect my jabra bt2070 with my computer running windows 7?
You can buy a bluetooth usb adapter and make your pc bluetooth enabled. I bought an I/o gear blue tooth adapter for $ 2.58 and it allows me to pair up my headset to my pc and I can go up to 500 ft away and hear perfectly.
All you need are 2.0 usb ports (high speed)
the adapter can cost up to $ 20 but it works and boy is it worth it!
Apr 20, 2011 | Jabra Bluetooth Headset - BT2070
Connect to iPhone 4
Hold the "Answer/End" button on your Jabra Bluetooth headset down until the LED light on the headset turns solid blue. The location of the button may vary based on which headset you have, but its appearance will be the same; it is the button that has an image of a telephone on it.
Click on the "Settings" icon from the main screen of your iPhone 4 .
Click on "General" in your iPhone's "Settings" menu.
Click on "Bluetooth" to access your iPhone's Bluetooth menu and then click the option to turn on your iPhone's Bluetooth connection. Once your iPhone's Bluetooth is turned on, it will search for available Bluetooth devices.
Select your Jabra headset by clicking on the icon that appears on your iPhone's screen.
Enter the passkey for your Jabra Bluetooth headset. The default passkey on Jabra headsets is "0000."
Click on "OK" on your iPhone 4 to complete the connection to your Jabra headset.
Tips & Warnings
The LED light on your headset must be solid blue to pair to your iPhone. A flashing light indicates your headset is not yet in pairing mode and your iPhone will not be able to connect to the headset.
Having your iPhone 4 Bluetooth turned on will drain your phone battery faster than normal.
Apr 13, 2011 | Jabra Bluetooth Headset - BT2070
Need to put bluetooth in pairing mode and lost instructions
how to connect a bluetooth to a cellphone
1. go to the menu on you cellphone and find connections-bluetooth
2. click options
3 be ready to click search for device (don't click it yet)
4. press the on button and your earpiece and hold till you get a solid bluelight.
5. when you get the solid blue light on earpiece click search for device
6. when it finds your device select it and click on it
7. it will then ask for a code or if you want to bond or pair the devices click yes and type 0000
8. it will ask you to confirm click connect
you should be able to connect.
if it works for you don't forget to rate me
thx
May 01, 2010 | Jabra BT350 Bluetooth Headset Headset
Connecting two devices on BT3030 headphones
A method to do pairing in "the second channel."
  1. Trun off BT3030 first.
  2. Continue pushing the power button till "Jabra" mark turns on pink next.
Attention: Continue pushing the power button after "Jabra" mark became the blue.
Mar 11, 2009 | Jabra BT3030 Wireless Headset
How to pair Jabra BT620s Bluetooth headphone with HP Laptop?
Hi
• At your computer Right click on the Bluetooth icon on the task bar.
• Select “Explore my Bluetooth places”.
• Click on “View devices in range” to see all available devices.
• Right click on the Jabra BT620s and select “Pair device”.
• Enter the four digit passkey: 0000 (4 zeros).
• Right click on the Jabra BT620s and select “connect”.
• The connection will be established automatically, otherwise if the Jabra BT620s is ringing,
press the answer/end button to confirm the connection.
Good Luck
Aug 10, 2008 | Computers & Internet
Computers & Internet Logo
301 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
