Question about Asko T761 Electric Dryer
ASKO T761 Dryer. Loud clicking noise from contactor coil right side rear, similar to auto starter solenoid with low batt. drum tries to move intermittently during clicking.
Posted by Herb Gullaksen on
3 Related Answers
Anonymous
  • 351 Answers
SOURCE: asko t761 dryer drum will not start rotating and belt is not broken
check the motor cap or belt on the pulley correctly
Posted on Aug 27, 2008
abhishek33
ABHISHEK.C
  • 1239 Answers
SOURCE: Asko T720 clothes dryer -
hi
The drum of the dryer is usually turned by a motor-and-belt assembly. There are two very clear signs that the belt is malfunctioning: You can easily spin the drum by hand when the dryer is off, or you hear a heavy thumping sound coming from the drum when the dryer is running. Here's how to test and replace the drum belt:
Step 1: Locate the belt by removing the back or front service panel. Depending on the type of dryer you own, you may have to prop up the drum to keep it from sagging. Don't let the drum hang; the bolts that hold it in the cabinet could be damaged. Don't remove any more parts than necessary.
Step 2: Identify the belt. The old belt may be threaded around the idler pulley and motor drive shaft. Draw a diagram showing how the pulley is installed so you'll be able to replace it properly. If the old belt is worn or frayed, but not broken, leave it around the drum as a pattern for positioning the new belt; cut the old belt and remove it when the new belt is in position.
Step 3: Remove the old belt from the pulleys and stretch the replacement belt into place. The new belt must extend around the dryer drum and the pulleys. The trick is to align the belt on the drum with the pulleys -- the ribs on the new belt go against the drum.
Step 4: Once the belt is aligned, turn the drum by hand, if possible, to make sure the belt is tracking. You may have to reassemble part of the cabinet to do this.
Posted on Sep 13, 2008
Anonymous
  • 10515 Answers
SOURCE: how do I replace the belt on my Asko T761 dryer?
How to install a belt on ASKO dryer
Belt Type: Flat belt with ribs
Installation Notes: Ribs go against drum
You could Refer to :-
http://fixitnow.com/wp/2006/05/08/asko-t700-dryer-wheel-drum-and-belt-replacement-instructions/
It would be a Generic one but would help you.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Mar 11, 2010
1helpful
Dryer making loud noise
Could be a few causes, but the most common is the drum roller wheel or wheels may have a bad bearing.
2answers
ASko dryer T761 goes bump bump bump when starting. sometimes we can wiggle drum around and get it to stop. Help!
I believe asko says this is normal at start up and should stop after the drum has been spinning for a bit.
Dryer is making a loud rumbling noise when drying - it is drying okay - but making a rambling noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
There is a very loud knocking noise when we run the dryer. It starts up immediately, and doesnt go away until we turn it off. We cleaned the fan mechanism, but that didnt help any.. any thoughts?
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
LG gas dryer DLG0452W drum makes a clicking noise
one of the dry drum baffle screw might be lose are there might be something caught inbetween the dry drum front seal are rear
2answers
How do I replace the belt on my Asko T761 dryer? Do I go in thru the front, the back? Are there instructions on-line for belt replacement?
Hope i helped you.
1helpful
Belt/Drum Noise
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
My t712c asko dryer is making some loud noises.
heatman101
nfgnc
Asko T761 Electric Dryer Logo
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Ekse
Are you an Asko Dryer Expert? Answer questions, earn points and help others
