I took out a memory card like normal, and tried to put another back in, and it won't go in. The gray release button does not pop back out. What do I do/how do I fix it?
SOURCE: I have a Canon powershot A700. I took out the old
As you've already tried sliding the card's locking switch, see this link for additional things that you can try.
SOURCE: my Canon powershot s400 camera won't read memory card
First, remove the card, and look in the slot for any bent flash card pins. If you see any, don't fret, it's possible that you can fix this yourself. See this article on how to unbend flash card pins.
But if no pent pins are seen, then the camera's clock battery has worn out, and is likely causing this problem. Unfortunately this battery is internal to the camera. But Canon will fix this for you (for the S400 only) for free, with free shipping. Please see the Canon advisory for your camera here.
SOURCE: I just purchased a 4gb memory card for my canon
ok, first off:
make sure the card is compatible with the camera and the camera is compatible with the card (reffer to the manuals of both products).
if all checks out, contact the manufacturer of the camera first, then do the same with the card.
if everything works up to this point, but you still cant get it to work, get a new camera.
SOURCE: just put in new san disk 4gb memory card and
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
SOURCE: My memory card just got stuck in my Canon Rebel
Repairing camera is a specialty. so unless you have this skill you'll have to let someone else fix it. i sent my camera to be fixed to: www.camerarepair.com they were reasonably priced and have a 6 month warranty. they're pretty quick also.
