Nikon D200 Digital Camera with 18-200mm Lens Logo
Question about Nikon D200 Digital Camera with 18-200mm Lens
My autofocus suddenly stopped working and a code of r11 comes up.
Posted by Cindy Stevenson on
fossils
  • 27 Answers
R11 isn't an error, it means that the memory buffer has room for 11 more shots.
Posted on Nov 10, 2013
1 Related Answer
Anonymous
  • 54 Answers
SOURCE: Why did my auto focus stop; now r11 appears in LCD
This might be obvious, but is the AF / M switch still on AF?
Posted on May 06, 2009
I have a nikon d40 that works great ewxcept for one day i was taking pictures and all of a sudden the camera would not take a picture in auto or manual and theres a warning sign flashing "r11" where the...
Slow down your shooting. The "R11" indicates that you can take 11 more images before the buffer is full and the camera will stop functioning until the images are moved to the memory card.
Select a smaller file size. Nikon cameras allow you to select from several sizes of JPEG as well as a RAW and a RAW + JPEG file. These files vary in size. If you select a smaller file size, the buffer will take longer to fill, allowing you to shoot longerTurn off long exposure noise reduction. This function causes the camera to expose twice for every image, and this can fill up the buffer quickly as those images are processed and written to the card.
  • Step 3 Select a smaller file size. Nikon cameras allow you to select from several sizes of JPEG as well as a RAW and a RAW + JPEG file. These files vary in size. If you select a smaller file size, the buffer will take longer to fill, allowing you to shoot longer.
  • Step 4 Turn off long exposure noise reduction. This function causes the camera to expose twice for every image, and this can fill up the buffer quickly as those images are processed and written to the card.
  • Read more: How to Fix the R11 Error on a Nikon D40x Digital Camera | eHow.com http://www.ehow.com/how_6327343_fix-nikon-d40x-digital-camera.html#ixzz0wC3WxqrT
    2answers
    Aoutofocus stopped working
    Please remove the battery and and then insert it again and test to automatically reset the setting.
    melnavz
    Well it filled up with water and stopped working the motor comes on but it wont drain spin or anything
    What you need to do is, take back off were timer is, check and see if resistor is burnt out R11. If R11 is Burnt you will need to replace it.
    2answers
    Hi K akima...have followed your advice, but no luck. When I go to continuous mode, it only lets me shoot a single shot, the display briefly reads r 08 then returns to r 09 again. I`ve tried my other lenses...
    nikon r09,r11, etc . it mean memory buffer of your camera. memory buffer is a temporary memory for your captured images before it store to memory card.
    if r00 it mean, you can't take a picture, even 1 picture... that because the camera buffer memory is full.
    the number of memory buffer will also drop if noise reduction on
    D200 not focusing and metering system not working
    There are some answers that may help you, here....
    https://www.photo.net/discuss/threads/d200-autofocus-fault.170857/
    Sigma 28-300mm autofocus problem
    You will need the interupter replaced the iris is closed down so the a/f will not lock on
    Nikon 18-55 zoom lens doesn't autofocus
    You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
    It sometimes gets moved accidently.
    Set to M the lens will not autofocus.
    1996 Ford Crown Victoria Shifting
    when was the last time you had the fluid and filter changed? This trans should be done every 30,000. Is it shuddering as the torque converter locks up?
    TSB 97-10-6 has a repair procedure for this ysmptom:
    Vehicles equipped with an AODE or 4R70W transmission may experience a torque converter clutch shudder or vibration. This occurs under light to moderate acceleration above 56 km/h (35 mph) while in 3rd or 4th gear. This may be due to either transmission fluid breakdown and/or the Powertrain Control Module (PCM) calibration.
    Verify that bulk fluid does not have moisture contamination. If suspected, use quart containers of MERCON®. Refill transmission with the proper amount of Motorcraft MERCON® Multi-Purpose Automatic Transmission Fluid (ATF) (XT-2-QDX).
    NOTE: DO NOT USE MERCON® V.
    Check emissions decal to verify vehicle has the latest calibration. If it does not, reprogram the PCM to new calibration level using Service Bay Diagnostic System (SBDS) or New Generation Star (NGS) Tester with May 1997 CD-ROM or later. Refer to the PCM Calibration Chart found at the end of this article for proper application.
    NOTE: VEHICLES SHOULD BE DRIVEN A MINIMUM OF 480 km (300 MILES) TO WORK THE NEW FLUID INTO FRICTION MATERIAL.
    PCM CALIBRATION CHART Application Old Calibration Old Part Number (-12A650-) New Calibration New Part Number (-12A650-) 1996 Crown Victoria/Grand Marquis 49S/Canada/High Altitude 6-18F-R05/R11 F6AF-AE 6-18F-R11 F6PZ-DJA 49S/Canada/High Altitude 6-18H-R05/R11 F6AF-BE 6-18H-R11 F6PZ-DKA Mexico 6-18H-R05/R11 F6AF-KE 6-18H-R11 F6PZ-DMA Police 6-18I-R05/R12 F6AF-CF 6-18I-R12 F6PZ-DLA California 6-18M-R05/R11 F6AF-DE 6-18M-R11 F6PZ-DNA California 6-18N-R05/R11 F6AF-EE 6-18N-R11 F6PZ-DPA
    2answers
    Autofocus has stopped working
    Olympus web site for a repair or replace option.
    Top Nikon Cameras Experts
    Steve
    David Shaub
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
