Okay the transmission is probably fine ,,,but if you are having these problems like this have your trans axles checked out ..anytime you put the vehicle in a bind that creates hard shifting you are heading for expensive repairs ..Have the ball joints checked as well to see if all of this smooths the transmission out ..It could be something simple ..also remember that a faulty steering can cause this
SOURCE: noise in front end, sounds
You say the rear wheel axles and bearings have been replaced, you mention nothing of the front wheels, you have the symptoms of a front wheel bearing being worn out, remove them and check for pitting in the bearing rollers or the bearing races, I am sure you will find a problem. Hope this helps solve your issue with the bearing noise.
SOURCE: what transmission will fit in an 89 gmc sierra?
if it has a 4.3 liter motor a 86 to a 97 if it has a 350 motor a 81 to a 96 will work hope this helps
SOURCE: Dodge Ram popping noise front left (drivers side) suspension
its a lot of times universal joints.. the ball joints break with no warning.
well when I go to turn left on a road, transmission starts to shift but then stops and down shift. im thinking being rear end is positive traction, when I turn its lifting the driver side tire up. Both back tires have to be on ground for both to turn the same way and being the driver side lifts up its just kinda rolling till it touches back down
well when I go to turn left on a road, transmission starts to shift but then stops and down shift. Im thinking being rear end is positive traction, when I turn its lifting the driver side tire up. Both back tires have to be on ground for both to turn the same way and being the driver side lifts up its just kind a rolling till it touches back down to grab and go.
