Question about Hitachi TravelStar 4K120 HTS421212H9AT00 120 GB Hard Drive
HITACHI 1TB HDD POWER FAIL LOGIC CARD DAMAGE SOLUTION
Posted by DEVENDRA on
Gary Nitowski
    Sergeant:
  • 326 Answers
I read a few answers to your problem, one is if it came with a "Y" style pigtail for the USB you need to connect both USB plugs,second that model has a improper alloy in its soldered connections and there is some soer of recall underway,try consumer reports for more information on the recall,mentioned something like a 100.00 refund avail. on certain models,good luck,Gary
Posted on Oct 26, 2013
How to connect a SATA2 HDD to a SATA1 motherboard?
It should work. If not, there are jumpers on some drives. Not a DIY task because it requires unusual skills. Does not always work in any case.
Jul 06, 2014 | Hitachi 1TB HDS721010CLA332 SATA2 U300...
Hp designjet error message 5.10
The 04C*** error is an internal data bus error. The hard disk drive and the Jetdirect card share this bus. With the power off, disconnect the HDD and remove the Jetdirect card. Power up and see if the error goes away and the plotter goes to ready. If it does, put the HDD and Jetdirect card back into the plotter one at a time and power up again to identify the failing part. If the error continues with the HDD and Jetdirect card removed, the bus controller has died and the main logic board needs to be replaced. Any of these parts can be ordered from: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
I can also be reached at 800-959-1575 to answer questions.
Apr 24, 2014 | HP DesignJet 500ps InkJet Printer
It dosen't works it make a sound like(tic tic tic about 5 second and will shut down)
HDD , if the power is good, is it? full spec voltage.
most FAST 1tb drives need a power pack,
has a 7 year warranty their home page states, so why not use that.
no HDD should make load noises, only ear close whiling sound.
soft ear close tics very very quiet is normal, load , NEVER.
if it makes noise say at arms distances that is bad.
2 causes:
1: the power pack is not plugged in, or missing or wrong pack used? (never run HDD with missing pack or wrong one.
2: drive bad. (bad drives click, when bad)
it can be the drive bad, or the power regulator toasted.
7 years. is a very long time. read the rules on your warr, card.
do not ever block the cooling slots of any HDD, case. ever.
or it will overheat, all fast drives can overheat, easy.
make sure that dont happen.
Oct 02, 2013 | Verbatim Sns1tb Store n Save 1 Terabyte...
Imminent harddrive failure
Hard Disk about to fail This warning means the hard disk will fail sometime in the near future. You need to back up your data regularly before the hard disk fails or you will lose your data.
Oct 01, 2012 | Hitachi 1TB HDS721010CLA332 SATA2 U300...
I want unlock hdd hitachi 1TB, you could hepl me ? thank you
My drive became locked with a password or I forgot my hard drive password. How do I gain access to my data?
Answers from Hitachi : Unfortunately, there is no way to bypass the security password feature of Hitachi hard disk drives. If the password is not known or has been misplaced, Hitachi will not be able to assist in gaining access to the data on the drive.
Reference link.
Nov 21, 2010 | Computers & Internet
Hi there, the red light on my ps3 is blinking and it wont take disc either. So what is the problem with it? thanks!
The Red light is due to the HDD (hard drive). There is one of 2 problems: 1. The connection is loose or 2. The HDD is just bad. This was an issue that has been discussed over in the Playstation forums and it seems that re-seating (removing & reinstalling) the HDD has solved the problem for many but some people have just received bad hard drives period. If you reinstall the HDD & it still beeps 3 times & gives you the red light, then you will have to replace your HDD. If I remember correctly, PS3s use Hitachi Laptop Drives. IMO, Hitachi is not well known for good drives. I replaced mine with a 160GB Western Digital drive I got for free a few months ago. I haven't had any problems since. Hitachi makes a good drive, but the ones that fail seem to fail really bad. Western Digital seems to make the best drives and
Apr 15, 2010 | Sony Playstation 3 (PS3) Console
Solid red light unit wont play
The Red light is due to the HDD (hard drive). There is one of 2 problems: 1. The connection is loose or 2. The HDD is just bad. This was an issue that has been discussed over in the Playstation forums and it seems that re-seating (removing & reinstalling) the HDD has solved the problem for many but some people have just received bad hard drives period. If you reinstall the HDD & it still beeps 3 times & gives you the red light, then you will have to replace your HDD. If I remember correctly, PS3s use Hitachi Laptop Drives. IMO, Hitachi is not well known for good drives. I replaced mine with a 160GB Western Digital drive I got for free a few months ago. I haven't had any problems since. Hitachi makes a good drive, but the ones that fail seem to fail really bad. Western Digital seems to make the best drives and they offer a very good warranty service as well.
Apr 10, 2010 | Sony Playstation 3 (PS3) Console
Is it safe to keep data cable connected without power cable
It is perfectly safe to remove the power cable from a hard drive but leave the data cable connected. Make sure that whenever you want to connect or disconnect the power cable, your computer has been shut down first. You could do it with the computer powered on as well, but this would not be good practice and you may put errors on your drive.
Sep 26, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Problem with Hitachi 1TB external hard drive
Most likely you just burnt up the adaptor. You can order another one from Hitachi.
The data is probably still intact on the drive itself.
You can connect it to your computer with an adapter that plugs into the drive itself and the usb port on your computer. It then shows up as a drive letter as normal.
You can buy these sata to usb adapters at most computer stores for around $25. Tiger has a nice selection:
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=sata%20to%20usb%20adapter
I would pick one with an external power supply. It also connects to your hd. The ends are keyed so you can't miss-plug them.
Or find a local computer tech (most have this cable in our toolkit) and he probably will copy your data in a few minutes for you.
Sep 04, 2008 | Hitachi 1TB External USB 2.0 Hard Drive
My external hard drive (HD) simply stopped working, should be no disk reading/ writing problems, the power is getting to the HD, but not to the drive as it does not spin, so from my own personal knowledge...
Sorry, but no spin, no win! Your hard drive enclosure has encountered a sever knock to cause headslap in the drive. You can rescue the data by purchasing a usb drive data reader kit. You take the drive out of the enclosure, attach the cables and plug it into a usb 2 port. You should be able to read the data no problem. Make sure you connect all cables to the drive, and it should be problem free for you.
Jul 18, 2008 | Hitachi Computers & Internet
Hitachi TravelStar 4K120 HTS421212H9AT00 120 GB Hard Drive Logo
44 people viewed this question
Top Hitachi Computers & Internet Experts
Marvin
Marvin
Davit Mamyan
Davit Mamyan
Michael Thomas
Michael Thomas
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
