Install wim download
Installing windows 8 but says install.wim missing
Posted by Peter Eady on
madd_jgi
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
Get another Win8 DVD that is work or re download a working version
Best Regards
Posted on Oct 29, 2013
Hi there, somebody install windows 8 pro and is not working properly. I want to restore my PC to windows 8, but its asking me to insert recovery media and I don't know what it is
You can download an ISO of your original OS from Microsoft and using your COA install it as a new install. Don't forget to install ALL drivers from the Samsung web site or it won;t work properly.
Feb 18, 2015 | Samsung 300E5C
How to install my laptop missing drivers for windows 8?
1) In the bottom right of the computer screen in the Desktop view of Windows 8, you should see a small flag, which is called the "action center icon". Click it to open the action center.
2) If the action center finds drivers are missing from your system, it will show you which ones under the "Maintenance" section. For information, click the "View message details" button.
3) For each of the missing drivers, click the direct download link to start the process.
4) Run the downloaded file
5) Simply proceed with the installation as directed and your drivers will be installed.
Jul 23, 2014 | Dell Inspiron Computers & Internet
When copying Windows Vista install dvd to usb, error message exit: Can`t copy install.wim (CRC) data error.
Make sure your install DVD is not scratched or full of finger prints. If you have another computer try using it to copy the DVD to USB. Some dvd players read dvd's better then others. If you need to, it is not illegal to download the software off the internet as long as you use the product key that came with your copy of the software when you install it. You could download the ISO from a torrent site and extract it to USB if you needed, with programs like MagicISO.
Chris
Jul 01, 2011 | Microsoft Windows Vista Ultimate Edition
I want to reboot my pc asus x5dc but it can t .but i have one message apeare when i want to continue the booting "cannot open WIM file" with a big word ERROR
What were you doing before this error? "Windows Imaging Format (WIM) is a file-based disk image format."
Try http://www.sevenforums.com/tutorials/15162-wim-file-extract-modify.html This tutorial is all about how to mount or modify install.wim or any .wim file.
May 31, 2011 | Computers & Internet
Code 80070246 how do i fix
To resolve this problem, replace the corrupted GlobalInstallOrder.xml file on the system with the same file from the Windows Vista installation media. To do this, follow these steps:
  1. Obtain the WIM filter driver from the Windows Automated Installation Kit (Windows AIK). To download and install the Windows AIK, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?FamilyID=c7d4bc6d-15f3-4284-9123-679830d629f2&DisplayLang=en (http://www.microsoft.com/downloads/details.aspx?FamilyID=c7d4bc6d-15f3-4284-9123-679830d629f2&DisplayLang=en)
  2. Click Start, point to All Programs, click Microsoft Windows AIK, right-click Windows PE Tools Command Prompt, and then click Run as administrator.
    If you are prompted for an administrator password, type the password. If you are prompted to continue, click Continue.
  3. At the command prompt, type the following command, and then press ENTER. MD c:\MountThis command creates a folder that is named Mount.
  4. Put the Windows Vista installation media in the CD or DVD drive.
  5. At the command prompt, type the following command, and then press ENTER: Imagex /mount DVDDriveLetter\sources\install.wim 1 \mount
  6. At the command prompt, type the following command, and then press ENTER: CD\mount\Windows\winsxs\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.0.6000.16386_none_07289f4cca5f6990This command moves to the source folder
  7. At the command prompt, type the following command, and then press ENTER: xcopy GlobalInstallOrder.xml %windir%\winsxs\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.0.6000.16386_none_07289f4cca5f6990This command copies the GlobalInstallOrder.xml file to the destination folder.
Mar 25, 2010 | Microsoft Windows Vista Home Basic Edition...
Windows vista
How To Make Vista Bootable DVD with WIM Downloaded Files If you have purchased Windows Vista online and taken the delivery of the latest operating system via web download from Windows Marketplace, you would ends up with a few downloads with .wim and .exe file extensions. Rather than paying additional shipping and handling charges, you can burn or create a bootable ISO DVD image from downloaded Vista files with the following trick, where the .iso image can subsequently write to a DVD. The DVD created will be the typical 32-bit Windows Vista DVD that available in retail channel, and can be used to clean install.
How to make a bootable Windows Vista ISO DVD media
1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
3. Exit from the Install Windows screen.
4. Download CDimage 2.52
5. Extract CDimage from CDimage.zip to the C:\ root directory.
6. Open a command prompt shell, and run the following command:
cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK)
1. Complete step 1 - 3 as above.
2. In the command prompt window, run the following command:
oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
3. Burn the ISO image file by using last step above.
Mar 24, 2008 | Computers & Internet
Computers & Internet Logo
133 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
