Question about Samsung Heating & Cooling
Samsung sh09bwha - Samsung Heating & Cooling
Posted by Nikos Kouros on
Have a Samsung split a/c .not working only indoor turn off isolater for 5mins turn back on wait a couple of mins turn on with remote a/c will start to work then goes out with red and green lights flashing...
this sounds like your AC is short on refrigerant or you have a defective sensor. When the AC condenser turns on feel the lines leaving with your hand. If it runs for a few minuites and does not get cold and sweats the gas pressure is low, if it does it could be one of your sensors in the evaporator.
There are usually two sensors/thermistors; take off the evaporator cover and one will be on the coil (room sensor) and the other inside a copper sleeve (coil sensor) You need a multimeter to check the ohmic value. your reading should be anywhere between 4K ohms to 10 K ohms, if your readings are in ohms (0-999) the sensor needs replacing with the original value, if values are mismatched the AC will not work
Feb 26, 2015 | Samsung Heating & Cooling
Need to unlock my samsung galaxy i577
Hi, What kind of lock has your Samsung Galaxy been locked to? If it is a network lock, You can unlock it safer and easier using unlock code. You can get the unlock code for a Samsung Galaxy from www.onlinegsmunlock.com/samsung-galaxy/rs7wp9/ at affordable cost. Here are the steps for unlocking a Samsung Galaxy,
1 - Switch ON your Samsung Galaxy with a NOT ACCEPTED SIM Card.
2 - Samsung Galaxy will ask for "Password".
3 - Enter the Unlock Code.
Sep 09, 2012 | Samsung Cell Phones
Forgot my password for samsung e 390
Hello Dear,
Type the code * 2767 * 3855 # and the phonewill reset to the factory settings. Other interestingcodes for Samsung phones: * # 0228 # BatteryInformation
* # 0673 # Test MP3
* # 0782 # Date and Time
* # 0842 # VibrationTest
* # 1111 # SoftwareVersion FTA
* # 1234 # Softwareversion (short)
* # 1235789 # StateControl of Integrity
Hardware Version * #2222 # FTA
* # 232337 # BluetoothBroadcast Address View
* # 32489 # State ofCiphering
* # 742695 # Softwareversion, Hardware Version, Date of Last Calibration Radiofrequency
(Equivalent to * # 8999* 8376263 #)
* # 8999 * 8376263 #Software version, Hardware Version, Date of Last Calibration Radiofrequency
(Equivalent to 742 695* # #) * # 1546792 * #Admin settings (WARNING: not to experiment!)
(* # * 73561 # OperatorCode, where applicable)
(* # 2456987 * # MasterKey) # * # 123580 TestMode main menu (not to experiment!, Equivalent to * # 9998 * 324 #)
* # 9998 * 324 # TestMode main menu (not to experiment!, Equivalent to * # 123580 #)
* # 0002 * 28346 # ItemMenu Handset Volume (sub-menu of the Test Mode Menu)
* # 0011 # NetworkConnection Status
(Same as in Test Mode,which not only returns to the main menu of the Test Mode)
* # 7412359 # Test MenuRadiofrequency
* # 9999 * 0 # NetworkMonitor
(Same as in Test Mode,which not only returns to the main menu of the Test Mode) * # 7465625 # setthe Phone List of Blocks # 7465625 * 27 *code # Remove the "PC Lock"
# 7465625 * 638 * Code# Remove the "Network Lock"
# 7465625 * 685 * Code# Remove the "Multi Lock"
# 7465625 * 746 * Code# Remove the "SIM Lock"
# 7465625 * 77 * code #Removes the "SP Lock"
# 7465625 * 782 * Code# Remove the "Subset Lock"
# 7465625 * 228 #Disable "Activa Lock"
# 7465625 * 2827 #Disable "Auto CP Lock"
# 7465625 * 28638 #Disable "Auto Network Lock"
# 7465625 * 28685 #Disable "Auto Multi Lock"
# 7465625 * 28746 #Disable "Auto SIM Lock"
# 7465625 * 2877 #Disable "Auto SP Lock"
# 7465625 * 28782 #Disable "Auto Subset Lock" Malicious code:
* 2767 * 3855 #Reset Full Phone (back as "just bought") * 7465625 * 27 *code # Set the "PC Lock"
* 7465625 * 638 * Code# Set the "Network Lock"
* 7465625 * 685 * Code# Set the "Multi Lock"
* 7465625 * 746 * Code# Set the "SIM Lock"
* 7465625 * 77 * code #Set the "SP Lock"
* 7465625 * 782 * Code# Set the "Subset Lock"
* 7465625 * 228 #Enable "Activa Lock" to restart the phone
* 7465625 * 2827 #Activate "Auto CP Lock" to restart the phone
* 7465625 * 28638 #Turn on "Auto Network Lock" to restart the phone
* 7465625 * 28685 #Turn on "Auto Multi Lock" to restart the phone
* 7465625 * 28746 #Turn on "Auto SIM Lock" to restart the phone
* 7465625 * 2877 #Activate "Auto SP Lock" to restart the phone
* 7465625 * 28782 #Turn on "Auto Subset Lock" to restart the phone These codes areworth a bit more for all Samsung phones, in particular: Samsung E390,Samsung Ultra Video F500, Samsung F510, Samsung F520, Samsung F700, Samsung SGHi520, Samsung i600, Samsung i620, Samsung L760, Samsung P910, Samsung P920,Samsung P940, Samsung SCHB100, Samsung SGH F600, Samsung SGH i550, Samsung SGHJ750, Samsung SGH I600, SGH i607 Samsung Blackjack, Samsung SGH P930, SamsungSGH Z630, Samsung Ultra Edition 12.1 (U700), Samsung Z100, Samsung Z105u,Samsung Z107V, Samsung Z110, Samsung Z130, Samsung Z140, Samsung Z140V, SamsungZ150, Samsung Z170, Samsung Z220, Samsung Z230, Samsung Z300, Samsung Z310, SamsungZ320, Samsung Z330, Samsung Z350, Samsung Z360, Samsung Z370, Samsung Z400,Samsung Z500, Samsung Z510, Samsung Z520, Samsung Z540, Samsung Z550 , SamsungZ560, Samsung Z600, Samsung Z610, Samsung Z620, Samsung Z650i, Samsung Z700,Samsung Z710, Samsung Z720, Samsung ZV10, Samsung ZV30, Samsung ZV40, SamsungZV50, Samsung ZV60, Samsung ZX10, Samsung ZX20. WARNING: Someof these codes may cause blockage or malfunction of the cell, therefore, it isunderstood that you use them at your own risk.
Dec 04, 2011 | Samsung SGH-E390 Cellular Phone
Themes for samsung monte s5230
Direct download themes http://www.mobileheart.com/cell-phone-reviews/samsung-2/samsung-S8000-Jet-1808.aspx http://www.umnet.com/phone/2300-Samsung_S8000_Jet http://gallery.mobile9.com/c/samsung-s8000-jet-wallpapers_2255/1/ http://www.tehkseven.net/wallpaper/samsung-s8000-jet-wallpapers.html FREE Ringtones http://www.mobiles5.com/topic/samsung-s8000-jet/
Jan 28, 2011 | Samsung Cell Phones
I cant find a driver for my samsung to conet with usb cable..
Samsung TV?
Samsung disk-drive?
Samsung digital-camera?
Samsung web-camera?
Samsung cell-phone?
What model?
Have you searched Samsung's web-site?
Dec 01, 2010 | Computers & Internet
Heating & Cooling Logo
22 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
