I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you. Good luck and take care.
To set speed dial numbers,with the handset down press the SPDL key(the key should flash)
enter in the 1 digit memory location code (1-9)
enter in the telephone number (up to 32 digits)
then lift and replace the handset. You should hear a confirmation tone and the SPDL key will stop flashing
To use pick up the handset, access a line and press SPDL and the location code (1-9)
FUNCTION SET 01 DATA REGISTRATION 02 DELAYED TRANSMISSION 03 POLLING 04 MEMORY REFERENCE 09 REPORT 11 UP 13 + 14 LEFT 15 SPACE 16 RIGHT 18 CLEAR 19 DOWN
Keys
1-20 are speed dial keys. If speed dial is not set, message is
displayed and manually entering the telephone number is prompted. Press
STOP to clear.
Pressing FUNCTION accesses the menus associated
with keys 1, 2, 3, and 4. After accessing a menu, the cursor keys, SET,
and occasionally the telephone key pad are used for selecting options
and setting values.
EG. Setting a speed dial number: FUNCTION
- DATA (01) - SET - SET - UP/DOWN to select speed dial number - SET -
UP/DOWN to set number/name - SET - UP/DOWN/LEFT/RIGHT/PHONE KEYPAD to
enter value - SET
EG. Setting unit telephone number FUNCTION - DATA (01) - DOWN once - SET - DOWN once - SET - PHONE KEYPAD to enter number - SET
EG. Retransmit from memory (assumes memory light is on) FUNCTION - MEM (04) - DOWN once - SET - UP/DOWN to select document number (LEFT/RIGHT to view associated telephone number) - SET
EG. Delayed transmission place
document into feed - FUNCTION - TX (02) - SET - PHONE KEYPAD to enter
time to send - SET - PHONE KEYPAD to enter phone number - SET - SET -
document is scanned and will be transmitted at set time
for full guide you will have to search and purchase one.
I have posted a video showing how to input telephone numbers into your directory. You decide which speed dial entry to use with which phone number. To access Speed dial easily either program a soft key to be an SPD button or the short code is 16followed by the speed dial number. look at 'abbeytel' on YouTube or www.abbeytelecom.com.
·Without lifting the handset, press redial button.Press the button on the strip you wish to store the telephone number on.Note that these 5 buttons are position numbers are 100, 101, 102, 103 and 104.100 is the first button above EXT PICKUP, and 104 is the first button below DND.These numbers can also be programmed using the method in Step 2 below and entering the position number (100 – 104). ·Enter the telephone number.Be sure to program the 9 in front of all local numbers, and 9+1+(Area Code) in front of long distance numbers. ·Press redial. ·To use the numbers stored on these buttons, lift the handset and press the button.
