Question about Hotpoint RFA60 Bottom Freezer Refrigerator
Hotpoint rfa 60 fridge freezer, power on but no coldness in either fridge or freezer
Posted by gfresh268 on
  • 3 more comments
  • gfresh268 Apr 27, 2009
    Yes
    Yes they are
  • tommytyrrell May 23, 2009
    i have the exact same problem power on but not cooling in fridge or freezer.
  • Robert Moller
    Robert Moller May 11, 2010
    All fans running?
  • Robert Moller
    Is compressor running?
Robert Moller
    Guru:
  • 1,524 Answers
Condenser is clean ? Then look in back of freezer for ice build up on coils
Posted on Apr 27, 2009
My Hotpoint Fridge/Freezer only works with the freezer at the bottom and the fridge is fed from the freezer via ducting to the fridge at the top ---- can anyone tell me why the freezer works perfectly and...
There has to be something restricting the air flow to the fridge. If the fan is running blowing cold air into the freezer, then it should be cooling the fridge too. Empty out the fridge and freezer and use a blow drier to blow hot air into the duct work. There could be an ice blockage not visible in the duct work.
Aug 15, 2014 | Hotpoint Refrigerators
I bought the hotpoint ice diamond fridge freezer the number on the outside of fridge is RFA 52 july 2010 i have had the thermostat on number 2 but the milk was iced up this morning so i have it on number...
Hello Jeanneary9,
Proper AIR CIRCULATION is critical to the
proper operation of the unit as a whole...
(I prefer my milk ICY cold... but fluid).
First thing to do is inventory your air vents
inside the FREEZER area... to ASSURE that
NONE are blocked (from open)...
Then inspect the air vent INTO the refrigerator
area that NONE of those are blocked (closed)
Most modern refrigerators give preference
to the milk storage shelf...
ELSE...
(first try a full 3 day DEFROST... (unloaded
with doors wide open... Then set to original settings
(three more days)))...
Only then you are looking at (sorting) a
DEFECTIVE thermostat...!!
I use (rather inexpensive) TAYLOR ($6 - USA)
refrigerator thermometers to regulate temperatures...
and STAY AWAY from "adjusting" as much as
Possible... as it can take UP TO 3 days (72 hours)
for the refrigerator to stabilize...
Hope this helps
Carnac the Magnificent
Jan 26, 2018 | Hotpoint Refrigerators
Operating instruction for iced diamond rfa 51p
high temp light on and not cooling in either freezer or fridge RFA51P ?
Mar 14, 2010 | Hotpoint Refrigerators
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
Frezer does not seem to be working in the cold
s it should the ambient temperatures that you said are way to cold to expect the freezer to operate properly. move it indoors and or contact the manufacture and see if the have a kit to put on the unit to work properly.
Jan 10, 2009 | Freezers
HOTPOINT FRIDGEFREEZER
Sounds like frosting up. Defrost completely...that can take 2 days. Restart. Also, clean the condenser. Check door gaskets, clean and replace as necessary. Don't keep door open longer than necessary.
Dec 20, 2007 | Refrigerators
Hotpoint RFA60 Bottom Freezer Refrigerator Logo
403 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
