I have a White Water Whirlpools tub with brass hardware and suction, and they need to be changed. Do I have to use their hardware, or can I use replacement hardware from a local Home Depot, Lowe's, etc?
First step is to remove the old hardware so you have something to compare it to. THere are two types/sizes of tub faucets on the market for deck mounted applications. If yours is mounted on the tub deck then it is a deck mounted application.
The faucet spread (distance between the threaded nipples on the bottom of the faucet) is going to be something close to 8" or it will be of variable distance. If the two handles and the spout are connected via hose then they are of variable length.
Bring the old faucet into the hardware store and compare it so you know you are getting the correct one. It is not hard but also not fun to have to adjust the holes in the tub deck to accommodate a different size.
AS for the suction.....I am assuming that you are referring to the inlet part o the pumping system and all of the equipment behind the tub. I always recommend that you use parts from the same manufacturer. It is extremely helpful to call them with all of the numbers you have to get a list of acceptable replacement parts.
Hope this helps.
SOURCE: How to Change White Water Whirlpool Tub Jet Hardware
I recommend that you consider spray painting the gold hardware with brushed nickel rusteoleum paint. IF you decide to go this route you must lightly abrade the gold surface with emery cloth then prime with rusteoleum primer, let that dry and the final coat will be the brushed nickel. I have done this and it turned out excellent. I get compliments on it.
Regarding your other issues, you will be happiest with white water parts. That being said, it is likely that locally procured parts might fit. I would get one set of parts and try them.
You will likely find the model number etc. on a plate in the mechanical compartment of the spa.
Click on the Link below. Jet Trim have to be matched up by sight.
Find the brand name of your bahtub and click on the name.
http://www.uspartscenter.com/category-s/4954.htm
Match up each item in your tub to what is shown online.
If you are unable to match the pieces up to what is shown online to what you have in your tub you may email us photos and we will match them up for you.
send photos to: [email protected]
Rod
US Parts Center
888-521-6183
Thank you for the reply. It is helpful, but I think I worded my issue incorrectly. By "hardware", I meant (but didn't specify) that I need to change the whirlpool jets and suction. The tub is old and the manufacturer doesn't carry it anymore, so I was wondering if I can replace the jets on my own? The tub faucet broke and I don't want to have to keep with the brass only to match the jets. All of my other hardware in the bathroom is chrome, and the brass clashes and looks like ****. Thanks!
