What you are being told is perform maintainence B and perform sub items 1, 2 and 5
MAINTAINENCE A CHECKLIST:
Replace engine oil
MAINTAINENCE B CHECKLIST: Replace engine oil and filter Inspect front & rear brakes Inspect parking brake & adjustment Inspect Tie rod ends, steering box & boots Inspect suspension components Inspect Driveshaft boots Inspect brake hoses and lines including ABS Inspect All fluid levels and conditions of fluid Inspect Exhaust system Inspect Fuel lines & connections
SUB ITEMS CHECK LIST
1:
Rotate Tyres
2:
Replace air cleaner element (Every 15,000 miles in dusty conditions)
Replace dust & pollen filter (Urban areas with high concentrations of soot, replace every 15,00 miles)
Inspect Drive belt
3:
Replace Transmission Fluid
4:
Replace Spark plugs
Replace Timing Belt
Inspect Water Pump (V6 Engines only) - If regular extreme conditions over 110 degrees f or under -20 degrees F, replace every 60,000 miles
Inspect Valve Clearance
I really like Istock (presonally make use of this 1) since it is actually simple. We additionally such as tinypic.
We detest detest detest photobucket. Far too sluggish! It's such as their own server is actually full. I understand others, however have not utilized all of them.
Istock promo codes is actually an additional great way in order to shop your own artwork
Symptom : No Image on the screen. I cannot turn on the monitor.
Checklist 1 : Is the power connected properly ?
Action : Check the power cord connection and supply.
Checklist 2 : Can you see "No Connection. Check Signal Cable" on the screen ?
Action : Check the signal cable connection.
Checklist 3 : If the power is on, reboot the computer to see the initial screen ( the login screen), which can be seen.
Action : * If the initial screen (the login screen appears, boot the computer in the applicable mode (the safe mode for Windows 98/95) and then change the frequency of the video card.
* Note : If the initial screen ( the login screen) does not appear, contact a service center or your dealer.
Sympton : I cannot see the ON Screen Display.
Checklist : Have you locked the On Screen Display (OSD) Menu to prevent changes ?
Action : Unlock the OSD by pressing the MENU button for atleast 10 seconds.
Symptom : No images on the screen. I cannot turn on the monitor.
Checklist 1 : Is the power cord connecte properly.
Checklist 2 : Can you see "Check Signal Cable" on the screen ?
Action : (Connected using the D-sub cable)
Checklist 3 : If the power is on, reboot the computer to see the initial screen (login screen), which can be seen.
Action : If the initial screen( the login screen) appears, boot the computer in the applicable mode (the safe mode for Windows ME/XP?2000) and then change the frequency of the video card.
Note : If the initial screen does not appear, contact the Service Center or your dealer.
Checklist 4 : Can you see "Not OPtimum Mode", "Recommended Mode 1440 X 900 60 Hz" on the screen.
Action : You can see this message when the signal from the video card exceeds the maximum resolution and frequency that the monitor can handle properly.
Adjust the maximum resolution and frequency that the monitor can handle properly.
Checklist 5 : There is no image on the screen. Is the power indicator on the monitor blinking at 1 second intervals ?
Action : The monitor is in Powersafe mode.
Press a key on the keyboard activate the monitor and restore the image on the screen.
If there is still no image on the screen, press the On button. Then press any key on the keyboard again to activate the monitor and restore the image on the screen.
I was looking for the same thing for my 1990 Johnson 175. I did a google search for "Outboard Motor Manuals" and found a manual that talked you through maintenance, repairs and services. I'm sure you can find one for your motor as well.
