charger not supported can be a software problemor a hardware problem.in an case we need to take it to nokia centre.before that check with another charger weather it is giving the same error or not.this is one of the phones which supports usb carging as well so whenever ou connect a charger you dont see anything on display.but if the phone is completely dead it takes atleast 15 to 20 minutes before it starts charging.
Can be battery problem..
Thanks
Fame !
http://www.fixya.com/support/r5164850-laptop_power_supply
However if there is voltage on the pins then check the voltage on the battery terminal pins in the laptop. If absent then the motherboard is faulty.
you need to use a multimeter to check and track the path of the voltage/current to confirm the area of fault in the charging section.
