SOURCE: how can I turn the flash off on a cannon power
Your menus will have options to be able to turn off the flash in certain modes.
The camera also has external buttons which will turn the flash on or off. Read your user manual.
The button which has the SET inside has four selectors. The right selector has a flash on/off button to turn the flash on or off. The flash usually will flash when set to flash all the time and not in AUTO mode. The AUTO mode may not allow you to turn off the flash. You probably have to choose another mode to allow the flash to be turned off.
If you do not have a user manual, here is a link to a free pdf download: User manual Canon A400
SOURCE: how do i turn off the flash on cannon power shot
The little lightning bolt on the right side of the function switch (3:00) gets you to the options. If you keep pushing it you will get the different settings. In the manual on Page 68 the different settings are given for the different icons.
For the manual Click Here.
Thanks for using Fixya. Happy New Year.
SOURCE: how do i turn off the flash on the cannon power
With the camera turned on in the mode to take pictures, press the top of the 4-way controller (lightning bolt) and you will see an icon come up on the LCD. Press the controller again until you see a lightning bolt with the barred circle around it (no flash). The flash options may not be available in some SCN (scene) modes, so use AUTO or P, if possible. Turning the flash off is a setting that is not remembered when the camera is turned off -- you have to set it each time you turn the camera on.
