Question about Water Filters & Coolers
The fuses in my primo water cooler model 900107. Need help
Posted by Jackie Ramos on
1 Related Answer
s_brooks8
s_brooks8
SOURCE: i have a pioneer table top water cooler model
Water is not getting cold, and it is making a loud noise then it stops.
Posted on Dec 20, 2012
Primo water cooler cant get hot water
Are you sure that the unit didn't blow its circuit breaker in the new location?
Jul 10, 2018 | Water Filters & Coolers
Tip
PRIMO BOTTOM LOAD WATER DISPENSER, BLINKING LIGHT
We started getting a blinking light... indicating the jug needed replacement... after installing a full jug. The unit would cycle, then the red blinking light would come back on. Upon careful inspection of the feed tube and lines, it was realized that the plastic line on the intake of the pump body had been inadvertently pulled out just slightly (presumably from jostling the jug around during replacement). I believe that this breaks the seal the unit requires for suction, and caused the fault. I simply pushed the (white) plastic line back into pump body and heard an audible 'click'. Unit works fine now. I hope this helps, as these units are not exactly cheap.
on Oct 30, 2013 | Primo Grills And Smokers Primo Bottom Load...
I have a primo bottom load water cooler model # 900130 the pump is not working. How do I fix it
I have missing or damaged parts. + - Select parts are available for your dispenser. Please complete the Contact Us form and provide the dispenser model number, serial number, and note the replacement part needed in the comments field. A Care Specialist will follow up with your request. A replacement fee will apply to out of warranty part requests.
900130 Primo Water Store
Dec 26, 2015 | Unknown Primo Deluxe Stainless Steel...
Why won't the red blinking light go off on my primo water cooler?
If the cooler or the water are not getting cold I would check for a high pressure reset if they are getting cold the compressor would working fine, you could also try flushing it, is there a pattern to the flash that may indicate a code................good luck! mine has developed a leak and does not heat less that 6 mo old pretty disapointing.
Jul 20, 2014 | Unknown Primo Deluxe Stainless Steel...
Primo water cooler red light blinking
What do I do with my Primo water dispenser whenever the red light keeps flashing I have a full bottle of water in there but it just keeps flashing I can turn it off and turn it back on or I can push the button in the door and it'll go off within the next 20 minutes it will come back on and the water's cold and then the water goes to lukewarm
Nov 25, 2013 | Unknown Primo Deluxe Stainless Steel...
Where is the reset switch on a Primo water cooler model YL1136S
My Primo Model:YL1136S Hot Water Quit Working How Do I Repair It
Aug 24, 2012 | Baby Gear
Primo water cooler
I JUST BOUGHT A PRIMO BOTTOMLOADING WATER DISPENSER AND ITS BEEN ON ALL NIGHT AND THE WATER IS WARM. I LOOKED ON THE BACK TO SEE IF THERE WAS A WAY TO TURN IT UP BUT FOUND NOTHING. PLEASE TELL ME WHAT TO DO. [email protected] COMCAST.NET
Jan 06, 2012 | Primo 900172 1.0 Gallon Industrial Water...
Water Filters & Coolers Logo
458 people viewed this question
Top Water Filters & Coolers Experts
john h
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
