Question about Xerox Phaser 7300DN Laser Printer
Paper jams by rolling to the fuser casing. Already replaced fuser module, but still having the same problem.
  • 51 Answers
You must configure the page size, because the configuration jams have a page shorter than the product that you put to print.
Posted on Oct 25, 2013
  • mcjeff01
    mcjeff01 Oct 25, 2013
    It's set to standard 8 1/2 x 11 paper
5 Suggested Answers
Anonymous
  • 208 Answers
SOURCE: Paper jam at fuser
1. Faulty/blocked fuser exit sensor or faulty/blocked POB sensor. The printer thinks paper is present at one of these sensors when there should not be paper present
Verify that the fuser exit sensor is not stuck
If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest.
Posted on Dec 19, 2007
Anonymous
  • 208 Answers
SOURCE: Paper jam 2 fuser
1. Faulty/blocked fuser exit sensor or faulty/blocked POB sensor. The printer thinks paper is present at one of these sensors when there should not be paper present. Verify that the fuser exit sensor is not stuck Verify operation of the POB sensor If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest
Posted on Dec 20, 2007
Rick Kasper
  • 2072 Answers
SOURCE: Phaser 7300N paper jam
Problem:
    The Printer's Front Panel Displays Jam At Top Cover; Open Top Cover To Clear (A7)
Cause:
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts):
1. Unsupported media. - Load supported media and set the media type correctly. 2. Dirty exit rollers. - clean the exit rollers. Paper catching on the duplex guide assembly. - Remove and reinstall the duplex guide assembly. Fuser not fully seated. - Reseat fuser
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers and exit rollers only when dust or
debris is visible.
2. Clean the LED assemblies.
3. Check version of print engine and image processor
firmware; as appropriate.
4. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
5. Review proper operation of printer using a customer
file, if possible.
6. Review with customer all work that was performed; also
discuss how to properly care for their printer.
Rev DT: 01 22 2003
Posted on Jan 23, 2008
Rick Kasper
  • 2072 Answers
What code is comming up with the jam? That would help me narrow it down for you.
Posted on Apr 05, 2008
Rick Kasper
  • 2072 Answers
SOURCE: xerox phaser 6120 laser printer paper jam fuser
You can remove the imaging unit, then
Depending on the stock being used for the job, raise or lower the left and right colored Fuser separator levers. The levers will stay in the raised or lowered position on their own.
the levers are green. The fuser itself is not easy to remove.
Do you have any warranty left on the machine? Or a depot repair agreement?
Posted on May 20, 2008
Hp2300 jams half way out of tray 1 and tray 2
1. Up to where paper traveled.. If its reached up to Fuser assembly & curl folds accrued under cartridge.. replace Teflon sleeve or Fuser assembly.
2. If paper traveled up to Fuser out(near 2-3 inch)...Clean/replace/flag Fuser out paper sensor
3. If paper traveled up to registration assembly:Clean registration sensors/flags.
4. Check pickup rollers.
Feb 20, 2013 | HP LaserJet 2300 Printer
HP 1010 , paper jam near fuser assembly.
Remove left,right,top & back cover, #check paper sensor flag & flag spring, found any dis location? correct it.Most of the cases spring dis location observed (see the snap shot for easy recognition)#clean fuser paper out sensor as well as check sensor flag.#check fuser teflon sleeve.
Mar 22, 2012 | HP LaserJet 1010 Printer
FUSER GETTING OVER HEATED IN XEROX PHASER 7400.SOMETIMES A4 PAPER GETTING JAMMED IN FUSER ,WITH A3 PAPER THERE IS NO PAPER JAMMING PROBLEM.
try to clean paper feeding rollers and chek fuser paper sensor, maybe paper comming too late...chek this just to be sure all its OK whit paper path and fuser.
...or replace fuser module!
Aug 23, 2010 | Xerox Phaser 7400DN Laser Printer
Xerox XD100 paper jamming every time.
The fuser is the problem. Most likely the fuser will need to be rebuilt or replaced.
Google a business called The Parts Drop. they have either the parts or the unit.
You may just have to take the fuser out and remove a badly jammed piece of paper in that module.
Shut the machine off for a half an hour. Remove the back cover. You will then see on the left side a black plastic bracket with 3 plugs on it. Disconnect those 3 plugs. Then open the right side door and toward the top is the fuser. It has yellow caution HOT labels on it. There are 2 silver phillips screws holding it in. Remove the screws and then remove the fuser unit and see if there is a paper in there. There are 2 screws that you can remove and the fuser will kind of fold open to inspect for bent fingers or one out of place.
Mar 30, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
DC 1250 Paper Jam when printing few copies
Well that problem is because there is not enought oil on the fuser roll. The problem is the oil pump. change it before make one irreversible damage to the fuser or pressure rolls. Do a full maintenance of the fuser module.
Apr 25, 2009 | Xerox DocuColor 12 Printer
What does E 2 mean on Xerox XD 100
PAPER JAM PROBLEM
The Main PWB sensed that a paper jam
exists within the paper path.
E2 Status Code (Without SDF) RAP
The Main PWB sensed a tray misfeed or a paper jam in the paper path.
Initial Actions
• Switch off the power and clear any document jam.
• Check for any obstructions in the paper path.
Procedure
Switch on the power. Enter diagnostic code 30-1.
Open then close the Fuser Gate to actuate and deactuate the Fuser Jam Sensor Q3 while
observing the Paper Jam lamp. The Paper Jam lamp comes on and goes off.
Y N
Go toFlag 2 and check the wires for an open or short circuit.
Manually actuate and deactuate the Paper Feed Sensor Q1 while observing the Toner Cartridge
lamp.
The Toner Cartridge lamp comes on and goes off.
Y N
Go to Flag 1 and check for an open circuit.
Place a piece of paper above the Fuser Gate and use the Manual Exit Knob move the paper
across the Exit Sensor Q4 while observing the Drum Cartridge Lamp.
The Drum Cartridge lamp turns on and off.
Y N
Go to Flag 3 and check for an open wire.
Manually actuate and deactuate Bypass Feed Sensor Q2 while observing the Auto exposure
lamp.
The Auto exposure LED comes on and goes off.
Y N
Go to Flag 4 and check for an open circuit.
Press the Clear button. Enter diagnostic code 6-2. Press the Start button. The Registration
Roll Solenoid can be heard switching on and switching off.
Y N
Press the Clear button. There is +24 VDC measured between CN103-1 and GND.
Y N
Replace the Main PWB PL 7.1.
Go to Flag 5 and check the wires for an open circuit. If the wires are good, replace the
Registration Roll Solenoid SOL3.
Press the Stop button. Paper jams in the fuser.
Y N
Check the following:
• Ensure that the paper tray guide is set to the correct width of the copy paper.
• Inspect the paper path from this tray and the paper registration area for an obstruction
such as a burr.
• Inspect the Registration Roll, PL 5.1 and the Pinch Roll, PL 1.4 for contamination
and wear. Clean (with Film Remover only) or replace as required.
Apr 03, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Paper Jam? Print quality
If the toner wipes off the printed pages, then the fuser is the problem....not hot enough or enough pressure to heat the toner to the paper. I would try to reseat the fuser...make sure it is making good electrical contact. I have also seen the paper actually wrap around the fuser roll, which would cause the same symptoms...be careful removing the paper if that has happened...the fuser roll can be easily damaged !
Jan 22, 2009 | HP LaserJet 2840 All-In-One Printer
My printer keeps telling me I have a paper jam there is not
There is either a sensor flag out of place, which is usually a small plastic piece, or you still have a small piece of paper stuck some where. Without knowing which machine we are talking about it's hard to say which it is.
Nov 18, 2008 | HP Office Equipment & Supplies
PC1060 canon copier
in your case you have to remove the fuser
I will try to guide you, most of the models are the same.
1-turn off machine and unplug
2-open the side door, you already know where the paper is it's most likely rolled up on a hot long roller, this is the fuser unit
3-with a phillips scredriver(star) remove 2-4 screws that hold the unit, it will have a plug most likely on the right hand side unplug
4-unit should slide out (unless there is a cover holding it
5- you can now see and work on the unit turning the gear by hand to remove the paper.
6-reverse the steps
Aug 12, 2008 | Office Equipment & Supplies
Xerox Phaser 7300DN Laser Printer Logo
60 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
