Bryant Furnace 350MAV code 31 - Heating & Cooling
Posted by steve lewis on
ndbooster
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 310 Answers
Probably a failure of the draft inducer fan motor, draft inducer blower, or the pressure switch that senses the operation of the draft inducer.
Posted on Nov 11, 2013
3 Related Answers
Anonymous
  • 96 Answers
SOURCE: Induced draft motor
The inducer motor is what takes the cabonmonoxide out of the house from the unit and should not be bypassed
Posted on Mar 08, 2009
flatech
Michael McQuay
  • 111 Answers
SOURCE: bryant programmable thermostat will switch on furnace
Turn the power off to the Air handler unit.
Remove the thermostat from the wall, (Just the face part).
Look on the back side of the thermostat and verify that the jumpers are set to electric and not gas, otherwise the fan will not run during heat mode, they come from the factory usually set for gas.
If this is a electric heater this will solve your problem, If it is gas then it will be more detailed. Once you put it back on keep in mind that most thermostats have a 3-5 minute delay so just give it a little time and the fan should then work once you have the jumpers in the correct position.
FlaTech
Thank you for using FixYa!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Posted on Nov 17, 2009
shastalaker7
Robert Horton
  • 1515 Answers
SOURCE: bryant furnace codes
If you have a Bryant split system, that is gas fired, and you are having a problem with it because of a flashing led, you need to remove the panel to excess the glued on chart that will tell you what the code is according to the amount of flashes its showing you. You may have 2 long flashes and one long, or something different? Look at the chart inside, and it will tell you what is wrong.
Sincerely,
Shastalaker7
A/C, Heating Contractor
Posted on Nov 21, 2010
On a Bryant furnace 373lav what is error code 41 furnace tries to light imonitor lights up but the won't light
Code 41= blower out of valid speed range. you will more than likely need a new motor module. they are not cheap 300$ to 400$. If you call a carrier or bryant tech out they should have a test module they carry on their truck that lets you know if its the furnace circuit board or motor module.
Jan 02, 2015 | Heating & Cooling
Bryant 345mav furnace shuts down early after one minute
Try to jump pressure switch as soon as the inducer come on and see if it stay longer. if it does you might have problem with draft or pressure switch itself defected.
Nov 28, 2013 | Heating & Cooling
Control board
Hello, check to see if the board is receiving 120 volts at the L1 and neutral terminals, if you are then the board will need to be replaced, if you are not getting power then trace the wirimg back to where the voltage stops, for example could be a bad door switch, fuse, circuit breaker. If it is the board then just write down where all the wiring goes or sketch it out on a piece of paper and then remove the board and take it to a Hvac supply store, that way they can match it up for you and get the exact board you need.
May 08, 2012 | Heating & Cooling
Bryant furnace plus 90 led code is blinking once then 3 times fast. What does it mean?
these codes are on the inside panel of the front cover of the furnace. lift off and look inside.there should be a code explain chart on the panel by the light. this panel will need to be replace correctly for the furnace to work as there is a door switch.
Jan 31, 2011 | Heating & Cooling
Code 33 - changed filter need to reset - how??????
Should reset by shutting off power to furnace and then back on With a Bryant if you turn power off and then on, if the thermostat is calling for heat when power is restored blower will run for couple minutes before trying to fire furnace. This is normal
Jan 23, 2011 | Bryant Heating & Cooling
Induced draft motor
Mar 08, 2009 | Carrier Heating & Cooling
Heating & Cooling Logo
499 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
