Dell Inspiron 6400 Notebook Logo
Question about Dell Inspiron 6400 Notebook
Designjet 1050c
Posted by Robert Michl on
Error code :0a00100000001 what is this
Hello. The error 0A0010 indicates an air pressure system failure. The APS is located under the ink supply station on the left side of the plotter. The assembly can be ordered from: C6072 60387 Designjet 1050C 1055CM APS Air Pressure System
The service manual with replacement instructions can be downloaded from: HP Designjet 1050C 1055CM repair parts and accessories
0b000d 00000012
Hello. 0B000D error during start-up indicates a 24VDC failure. This is generally caused by a failed DC power supply. There are 2 types of power supplies - 1 for the 1050C series and 1 for the 1050C Plus series. They can both be found at: HP Designjet 1050C 1055CM repair parts
Red light comes on nothing ells
The Designjet 1050C Plus does not need the hard disk drive to boot. When only the red light comes on, the firmware ROM is probably missing. Open the small panel on the back of the plotter to access the memory and ROM slots. If the FW ROM and memory are missing, you will need to buy them to make the plotter boot. They can be purchased at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Cyan color not printing but ink indicator high
You probably have a bad trailing cable or bad carriage. Start by replacing the cable first. Parts available at: http://www.lpscomputer.com/p-2296-c6074-60418-designjet-1050c-1055cm-trailing-cable.aspx
2answers
Hp designjet 1050c ,wat year was de 1 one made ,this type printer
By looking at the user guide, around the middle of 1998.
Here is a link to the user guide if you are interested:
HP DesignJet 1050c User Guide
At the end of it, it says that the first edition was July 1998, so the printer was no doubt released around that same time.
Thanks for using Fixya.
Oh, and should you download that manual, be patient. It is over 14MB.
HP DesignJet 1050C stops printing - no error message
check all connectors on main pca. check trailing cables on carriage assembly. main pca may be bad.
1helpful
Configure of hp designjet 1050c
Manuals for the driver and plotter setup can be found here:
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=24023&lang=en&cc=us
1helpful
2answers
How do you resolve a hp designjet 1050C printhead path (1) - turn power off and check issue
How do you resolve a hp designjet 1050C printhead path (1) - turn power off and check printhead path Type 1
Clive
Clive
Steve Sweetleaf
Steve Sweetleaf
