Question about HP PSC 1610 All-In-One InkJet Printer
Says I'm using the incorrect black cartridge. I'm using 94 just like I'm supposed to.
Posted by Terry Quinn on
ONE-Touch-Solution
  • HP Master
  • 1,679 Answers
Are you getting error related to incompatible ink or Ink cartridge defective and this is Genuine cartridge purchased, then check for the Expiry date on the cartridge and call HP support to get assistance.
If the cartridge is defective and if the cartridge is still in warranty, You can probably expect to get a replacement cartridge without charges.
1-800-474-6836
Regards,
Sean
Posted on Oct 25, 2013
2 Related Answers
Anonymous
  • 21 Answers
SOURCE: Black Ink Cartridge error
clean the head With alcohol ,dry put it back
the head is jam !
Posted on Mar 10, 2008
Anonymous
  • 78 Answers
SOURCE: I installed a refilled HP 94 cartridge in my HP
This is a firmware issue with this printer model, and is fairly common. Try the following: remove both of the print cartridges, close the lid, wait for any noises to stop, and pull the power plug out of the back of the printer while it is still on. Wait at least 10 minutes with the cord disconnected. Plug the power back into the printer, wait for the noises to stop, and then reinstall the cartridges, black first (very important), and then the color. This will force the printer to reload its ram memory and should take care of the glitch. Let me know if you need further assistance, as I would like to be sure your problem is fixed.
Posted on Sep 30, 2010
1510 black cartridge can print how many pages
There are 2 black cartridges which can be used in PSC 1510 ie 92 and 94
92( 5.5 ml) can print around 210 pages if its being used with HP 93 ( Tricolor) cartridge
94(12 ml) can print around 470 pages if its being used with HP 95 ( Tri Color) cartridge
You can also check it on HP Website click here to check on HP
Apr 04, 2011 | HP PSC 1510 All-In-One InkJet Printer
Canon Pixma Mp830
Hi there, if you forced it in then you may need to force it out again
Mar 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
My printer has decided that the black printer cartridge that has worked for months is the "incorrect cartridge". Figured it was a software problem, since my other printer now gives the same error...
I am having the same problem, I tried to replace the black cartridge and now it says it is the incorrect cartridge, so I put the old one back in and get the same error message.
Feb 09, 2011 | HP PSC 750 All-In-One InkJet Printer
I installed a refilled HP 94 cartridge in my HP PSC 2355 All-in-One printer. It worked well for several weeks but then I suddenly got the following Error Messages: "Incorrect Cartridge - Black ink...
Sep 30, 2010 | HP PSC 2355 All-In-One InkJet Printer
The printer says that the black ink cartridge is bad. Replace
Please use HP 94 or HP 96 black ink cartridge.
Regards,
Rizwan.
Mar 01, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Hp6940 ink and printing problems
you may have a bad print cartridge or it has gone bad...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 21, 2009 | HP Deskjet 6940 InkJet Printer
Display shows: printer cartridge incorrect
It seems like you are using incorrect printer cartridges.....
Make sure that part number on ink cartridges should be :
MK990 Cartridge, Ink, Standard, Series-9, Black CTRG,INK,STD,SERIES-9,BLK 0 1 0 Yes 1 N MK991 Cartridge, Ink, Standard, Series-9, Color CTRG,INK,STD,SERIES-9,CLR 0 1 0 Yes 1 N MK992 Cartridge, Ink, High-Yield, Series-9, Black CTRG,INK,HIYLD,SERIES-9,BLK 0 1 0 Yes 1 N MK993 Cartridge, Ink, High-Yield, Series-9, Color CTRG,INK,HIYLD,SERIES-9,CLR 0 1 0 Yes 1 N MK995 Cartridge, Ink, Series-9, Photo
Nov 10, 2008 | Dell 962 Photo All-In-One InkJet Printer
I have loaded a new Lexmark black cartridge , after using a coloured one and the massage says "incorrect cartridge, or something like that, what do I do to make it work.
These printers can use a B&W cartridge and a color cartridge, or two color cartridges for enhanced color. I believe when you switch these it is supposed to detect automatically and change it in the driver settings. If it isn't the case for what ever reasonhowever, you should still be able to set it manually in the printer properties. If this fails, just try turning off the printer, unplugging the printer and moving it to another USB port, and turning it back on. Maybe you need to kick start the detection process.
Aug 08, 2008 | Office Equipment & Supplies
Cartridge is not intended for use in this printer
Under the setup menu, then under preferences, there's an item where you can change the language & country. I don't know if that will have any affect on the cartridge selection though.
Feb 29, 2008 | HP Officejet 7210 All-In-One InkJet...
HP PSC 1610 All-In-One InkJet Printer Logo
46 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
